Hello everyone,
I’m encountering an issue with my Storj node. My Docker container keeps restarting in a loop and I’m seeing errors in the logs. Here are the details of my configuration and the errors I’m encountering:
Docker Container Configuration
-p 28967:28967/tcp \
-p 28967:28967/udp \
-p 127.0.0.1:14002:14002 \
-e WALLET="0x9c6c8e7dc6b8bb264469abbddbfd985cfe33888e" \
-e EMAIL="myemail@myemail.com" \
-e ADDRESS="nelexstorj.ddns.net:28967" \
-e STORAGE="4TB" \
--user $(id -u):$(id -g) \
--mount type=bind,source="/home/nelexstorj/.local/share/storj/identity/storagenode",destination=/app/identity \
--mount type=bind,source="/mnt/disk1",destination=/app/config \
Docker Container Logs
sudo docker logs --tail 50 storagenode
2024-05-26T11:53:38Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-05-26T11:53:38Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-26T11:53:38Z ERROR failure during run {"Process": "storagenode", "error": "piecestore monitor: error verifying location and/or readability of storage directory: content of file is not a valid node ID: ", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: content of file is not a valid node ID: \n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:160\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:143\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Error: piecestore monitor: error verifying location and/or readability of storage directory: content of file is not a valid node ID:
2024-05-26 11:53:38,863 INFO exited: storagenode (exit status 1; not expected)
2024-05-26 11:53:39,867 INFO spawned: 'storagenode' with pid 46
2024-05-26 11:53:39,868 WARN received SIGQUIT indicating exit request
2024-05-26 11:53:39,868 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2024-05-26T11:53:39Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2024-05-26 11:53:39,871 INFO stopped: storagenode-updater (exit status 0)
2024-05-26T11:53:39Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2024-05-26T11:53:39Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2024-05-26T11:53:39Z INFO Operator email {"Process": "storagenode", "Address": "nelson.sobralrosa@gmail.com"}
2024-05-26T11:53:39Z INFO Operator wallet {"Process": "storagenode", "Address": "0x9c6c8e7dc6b8bb264469abbddbfd985cfe33888e"}
2024-05-26T11:53:39Z INFO server kernel support for server-side tcp fast open remains disabled. {"Process": "storagenode"}
2024-05-26T11:53:39Z INFO server enable with: sysctl -w net.ipv4.tcp_fastopen=3 {"Process": "storagenode"}
2024-05-26T11:53:40Z INFO Telemetry enabled {"Process": "storagenode", "instance ID": "126aKMo19eBKkVhXnHmm34sax4F3M6CpqGJYNLSy4eJTNoVK39P"}
2024-05-26T11:53:40Z INFO Event collection enabled {"Process": "storagenode", "instance ID": "126aKMo19eBKkVhXnHmm34sax4F3M6CpqGJYNLSy4eJTNoVK39P"}
2024-05-26T11:53:40Z INFO db.migration Database Version {"Process": "storagenode", "version": 57}
2024-05-26T11:53:40Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"Process": "storagenode"}
2024-05-26T11:53:41Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"Process": "storagenode"}
2024-05-26T11:53:41Z INFO Node 126aKMo19eBKkVhXnHmm34sax4F3M6CpqGJYNLSy4eJTNoVK39P started {"Process": "storagenode"}
2024-05-26T11:53:41Z INFO Public server started on [::]:28967 {"Process": "storagenode"}
2024-05-26T11:53:41Z INFO Private server started on 127.0.0.1:7778 {"Process": "storagenode"}
2024-05-26T11:53:41Z INFO bandwidth Persisting bandwidth usage cache to db {"Process": "storagenode"}
2024-05-26T11:53:41Z INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details. {"Process": "storagenode"}
2024-05-26T11:53:41Z INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-26T11:53:41Z INFO lazyfilewalker.trash-cleanup-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-26T11:53:41Z INFO trust Scheduling next refresh {"Process": "storagenode", "after": "6h10m10.21397249s"}
2024-05-26T11:53:41Z INFO lazyfilewalker.trash-cleanup-filewalker subprocess started {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-26T11:53:41Z WARN piecestore:monitor Disk space is less than requested. Allocated space is {"Process": "storagenode", "bytes": 3736761913344}
2024-05-26T11:53:41Z ERROR services unexpected shutdown of a runner {"Process": "storagenode", "name": "piecestore:monitor", "error": "piecestore monitor: error verifying location and/or readability of storage directory: content of file is not a valid node ID: ", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: content of file is not a valid node ID: \n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:160\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:143\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-05-26T11:53:41Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-05-26T11:53:41Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-05-26T11:53:41Z ERROR gracefulexit:chore error retrieving satellites. {"Process": "storagenode", "error": "satellitesdb: context canceled", "errorVerbose": "satellitesdb: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits:197\n\tstorj.io/storj/storagenode/gracefulexit.(*Service).ListPendingExits:59\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).AddMissing:55\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run:48\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-05-26T11:53:41Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-05-26T11:53:41Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-05-26T11:53:41Z ERROR version failed to get process version info {"Process": "storagenode", "error": "version checker client: Get \"https://version.storj.io\": context canceled", "errorVerbose": "version checker client: Get \"https://version.storj.io\": context canceled\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tstorj.io/storj/private/version/checker.(*Client).Process:89\n\tstorj.io/storj/private/version/checker.(*Service).checkVersion:104\n\tstorj.io/storj/private/version/checker.(*Service).CheckVersion:78\n\tstorj.io/storj/storagenode/version.(*Chore).checkVersion:115\n\tstorj.io/storj/storagenode/version.(*Chore).RunOnce:71\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/version.(*Chore).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-05-26T11:53:41Z ERROR nodestats:cache Get pricing-model/join date failed {"Process": "storagenode", "error": "context canceled"}
2024-05-26T11:53:41Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-05-26T11:53:41Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-05-26T11:53:41Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2024-05-26T11:53:41Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-05-26T11:53:41Z INFO lazyfilewalker.trash-cleanup-filewalker subprocess exited with status {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "status": -1, "error": "signal: killed"}
2024-05-26T11:53:41Z ERROR pieces:trash emptying trash failed {"Process": "storagenode", "error": "pieces error: lazyfilewalker: signal: killed", "errorVerbose": "pieces error: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:187\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:419\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2024-05-26T11:53:41Z ERROR gracefulexit:blobscleaner couldn't receive satellite's GE status {"Process": "storagenode", "error": "context canceled"}
2024-05-26T11:53:41Z ERROR failure during run {"Process": "storagenode", "error": "piecestore monitor: error verifying location and/or readability of storage directory: content of file is not a valid node ID: ", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: content of file is not a valid node ID: \n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:160\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:143\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-05-26 11:53:41,165 INFO stopped: storagenode (exit status 1)
2024-05-26 11:53:41,166 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
Identity directory
nelexstorj@ubuntu:/mnt/disk1$ ls -l /home/nelexstorj/.local/share/storj/identity/storagenode
total 24
-rwx------ 1 nelexstorj nelexstorj 558 May 26 12:22 ca.1716718937.cert
-rwx------ 1 nelexstorj nelexstorj 1088 May 26 12:22 ca.cert
-rwx------ 1 nelexstorj nelexstorj 241 May 26 00:12 ca.key
-rwx------ 1 nelexstorj nelexstorj 1096 May 26 12:22 identity.1716718937.cert
-rwx------ 1 nelexstorj nelexstorj 1626 May 26 12:22 identity.cert
-rwx------ 1 nelexstorj nelexstorj 241 May 26 00:12 identity.key
Storage disk
nelexstorj@ubuntu:/mnt/disk1$ ls -l /mnt/disk1
total 104
-rwx------ 1 nelexstorj nelexstorj 558 May 24 13:31 ca.1716539445.cert
-rwx------ 1 nelexstorj nelexstorj 1088 May 24 13:31 ca.cert
drwx------ 2 nelexstorj nelexstorj 4096 May 24 13:26 config
-rwx------ 1 nelexstorj nelexstorj 11645 May 24 21:57 config.yaml
drwx------ 3 nelexstorj nelexstorj 4096 May 24 13:31 identity
-rwx------ 1 nelexstorj nelexstorj 1096 May 24 13:31 identity.1716539445.cert
-rwx------ 1 nelexstorj nelexstorj 1626 May 24 13:31 identity.cert
-rwx------ 1 nelexstorj nelexstorj 241 May 24 13:31 identity.key
drwx------ 2 nelexstorj nelexstorj 4096 May 24 14:23 identityfolder
drwx------ 2 nelexstorj nelexstorj 16384 May 24 10:46 lost+found
drwx------ 4 nelexstorj nelexstorj 4096 May 24 16:27 orders
drwx------ 2 nelexstorj nelexstorj 4096 May 24 16:27 retain
-rwx------ 1 nelexstorj nelexstorj 32768 May 26 14:43 revocations.db
-rwx------ 1 nelexstorj nelexstorj 487 May 24 16:25 start-storagenode.sh
drwx------ 5 nelexstorj nelexstorj 4096 May 26 14:43 storage
-rw------- 1 nelexstorj nelexstorj 933 May 26 14:43 trust-cache.json
Mapping
sda 8:0 0 3.6T 0 disk
└─sda1 8:1 0 3.6T 0 part /mnt/disk1
Docker list
4568e3031605 storjlabs/storagenode:latest "/entrypoint" About an hour ago Restarting (0) 31 seconds ago storagenode
Hardware and linux version
Rasperry pi5
Disk 4Tb USB
ubuntu 23.10
Any idea what could be wrong ?
Cheers
