Issues with Nextcloud
Hi, as far as i can see, there are issues with Nextcloud and the Gateway.
See https://github.com/storj/gateway/issues
Any idea if they will be fixed or if we can safely deploy Nextcloud along with the Gateway?
Thanks.
Hi there, thanks for checking in with us. Our team has fixed the issue but hasn’t made a new release for our gateway library. Once the new release is published(hopefully soon!), the nil pointer issue should be solved.
Hi, great news. Will give it a try ASAP. Thanks.
