I had the protocol set to TCP/UDP. I also checked my firewall rule, and it is in fact in their set. I have also tried to do each port on its own, meaning one port is TCP and another is UDP. it’s still a no go
And what about this?
Also, do you by a chance have any geo-filtering enabled on your firewall?
how would i find that config on windows?
I did everything right except one thing: when you install the software, it says IP address. I was using the local LAN on the network, not my ISP’s IP; that was the issue. I’m a dumbass, fellas, and I’m so sorry for all the trouble I created. Instead of me using my ISP anyway, I can make another domain, of course. Cloudflare with NginxProxy with SSL with a cname is that possible or has any tried it before
