Issues with QUIC Configuration on Multiple Storj Nodes on the Same Machine
I’ve set up three Storj nodes on the same machine and assigned three different public IP addresses to each node. Here is my configuration:
Node 1:
    -p 28901:28967/tcp \
    -p 28901:28967/udp \
    -p 127.0.0.1:14001:14002 \
    -e WALLET="0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" \
    -e EMAIL="xxxxxxxxxx@gmail.com" \
    -e ADDRESS="xx.xx.xx.21:28901" \
    -e STORAGE="13.1TB" \
    --user $(id -u):$(id -g) \
    --mount type=bind,source="/storj/identity/storagenode",destination=/app/identity \
    --mount type=bind,source="/storj/data",destination=/app/config \
Node 2:
    -p 28902:28967/tcp \
    -p 28902:28967/udp \
    -p 127.0.0.1:14002:14002 \
    -e ADDRESS="xx.xx.xx.22:28902" \
    --mount type=bind,source="/storj2/identity/storagenode2",destination=/app/identity \
    --mount type=bind,source="/storj2/data",destination=/app/config \
    --name storagenode2 storjlabs/storagenode:latest
Node 3:
    -p 28903:28967/tcp \
    -p 28903:28967/udp \
    -p 127.0.0.1:14003:14002 \
    -e ADDRESS="xx.xx.xx.23:28903" \
    -e STORAGE="15TB" \
    --mount type=bind,source="/storj3/identity/storagenode3",destination=/app/identity \
    --mount type=bind,source="/storj3/data",destination=/app/config \
    --name storagenode3 storjlabs/storagenode:latest
Despite this setup, I am receiving the following error for Nodes 2 and 3:
“QUIC is misconfigured. You must forward port 28967 for both TCP and UDP to enable QUIC. See Step 3. Setup Port Forwarding - Storj Docs on how to do this.”
Node 1 seems to be working fine without this error.
Nodes 2 and 3 are using different ports for communication (28902 and 28903).
I have ensured that port forwarding is set up correctly on my router for the respective ports and IP addresses. Each node is running on a different public IP, so I’m not sure why this misconfiguration message is appearing.
Questions:
  1. Is there a specific requirement for QUIC configuration that I might be missing for nodes running on different ports?
  2. How can I ensure that QUIC is configured correctly for multiple nodes on the same machine with different IP addresses?
Any insights or suggestions would be greatly appreciated!
How long have you waited? I often see a node be Online after startup… but QUIC says Misconfigured… then I check back in an hour and they’re both OK. (I think the Satellites’ online-check and quic-check may be at different times?)
Edit: It looks like this page lets you manually run a QUIC check?
About 10+ months ago, Go bumped their lib for UDP use, screwing up STORJ’s implementation - breaking some backward compatibility.
1.) You can completely ignore this problem as UDP still isn’t really used.
2.) I would guess you can correct the Quick issue by specifying a specific unique adapter/pathway IP per instance. ie: -p 192.168.1.10:28901:28967, but I don’t run Docker- YMMV.
3.) If you change start order of your nodes, it should notice: it’s the first one started & subsequently confirmed that gets the quick OK.
GL
1 cent
2.) * Credit @arrogantrabbit, maybe it’s enough to change the internal port & your start params to match ie: 192.168.1.11:28901:28901 … Betting AR can confirm.
Did you configure the buffer size as in Linux Configuration for UDP - Storj Docs ? Check your storagenode log on startup, there is a warning if buffer size is too small. I use net.core.rmem_max=7500000 with multiple docker nodes all OK, same docker parameters as you.
any chance it’s a firewall port forward problem? ports 28901 and 28903 may not be making it from your router to your node box?
