I have not specified a debug port, but I am good at following directions. Although if it is easier to wait for someone else who already has access to the debug port, no worries. I am happy to help if I can though. I do not know how to determine the debug port.
sorry, not able to help on this one. My nodes have only been up for about 98 hours. I was installing some new light switches the other day and I stopped my nodes for about 30 minutes while I had the circuit to my office turned off as I was unsure if my connected UPS would last the entire duration as I have various other devices connected to it.
iām not mad⦠iām disappointed lol
I have run:
-p 127.0.0.1:7777:7777
uptime 172h 31m (2020-09-21T15:27:03.043Z)
What command should I enter?
I have 331 hours uptime, but⦠apparently I forgot to set a debug port again after the last time I let the node recreate the config.yaml. Having to do this through CLI within docker, Iām struggling a little to find what youāre looking for. I only found this.
/app # wget -O - http://127.0.0.1:39736/mon/stats | grep piecedeleter-queue-full
Connecting to 127.0.0.1:39736 (127.0.0.1:39736)
writing to stdout
- 100% |*********************************************************************************************************************| 586k 0:00:00 ETA
written to stdout
writing to stdout
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces count=170960.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces sum=4910217986971.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces min=3862.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces avg=28721443.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces max=5324050202.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces rmin=29596.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces ravg=2584719.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces r10=38486.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces r50=70223.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces r90=9623895.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces rmax=22486988.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces recent=53903.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces count=170960.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces sum=2697468.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces min=0.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces avg=15.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces max=291.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces rmin=0.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces ravg=1.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces r10=0.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces r50=0.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces r90=2.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces rmax=31.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces recent=0.000000
written to stdout
No mention of piecedeleter-queue-full
Not sure if this helps. Let me know if I can try something else. (Ps. little surprised curl wasnāt available inside the container, but this worked. That thing is light weight )
Nice one. Just to be sure that if from your node with the 400 GB of trash?
Yes, it is most definitely so (needed 20 chars )
so i assume this command parameter cannot be placed randomly in the run command sequence, since it seems that itās not the parameter but its location which makes it workā¦
@littleskunk or @BrightSilence so what to i add to set this up⦠so itās easy to find in future?
tried adding it at the end of the run command but that didnāt seem to take, so added it before the --mount
which seems to have done the job, now i can access the info by going to http://storagenode-ip:5999/mon/funcs
oh yeah and ofc used the storagenode-ip instead of 127.0.0.1
adding it sooner than the other -p parameters seems like a bad idea, so made sense to put it just before the --mount 's started⦠i guess that when the --name storagenode storjlabs/storagenode:latest parameter is given maybe the parameter input endsā¦
seems a bit confusing that everything is a -p parameter but docker thing i suppose.
and also added the debug.addr ā:5999ā to config.yaml
So it turns out Stefan deleted ~100 TB of old data from old buckets. Somewhere between satellite and storage nodes we lost a lot of deletes and later garbage collection fixed it. The issue I see here is not so much that the storage nodes are not getting paid. 400 GB unpaid for 2 weeks is just 30 cent. The big problem I see is more about what happens if we ever implement a bug in garbage collection. Within 7 days we want to be able to recover the data from the trash folder back to the storage node. This only works if the storage nodes trust garbage collection. As soon as storage nodes start to delete the trash folder from time to time we also lose the option to recover. I hope we can find the issue and fix it. In the meantime please do not delete anything in the trash folder.
Docker node update is coming ⦠can I do it?
Iām curious how you determined the random port that monkit was attached to inside the container.
I didnāt have to, I have docker run in my command ā¦
That was actually meant for Bright. I will definitely be adding that port map and config file entry for future use.
Oh Iām not worried about the payout. In my specific case even the 30 cents doesnāt apply as I have plenty of free space. So whether it temporarily stores garbage or is sitting there empty really has no impact. Iām just looking to help find if there is something bad going on.
Open a shell inside the container
docker exec -it storagenode /bin/sh
Then list ports being listened to
netstat -tulpn | grep LISTEN
Youāll find 28967, 7778 and the one youāre looking for.
Brilliant, thanks! Iāll add my data to the pile:
/app # wget -O - http://127.0.0.1:41969/mon/stats | grep piecedeleter-queue-full
Connecting to 127.0.0.1:41969 (127.0.0.1:41969)
- 100%
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces count=42607.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces sum=325940.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces avg=7.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces max=98.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces ravg=0.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces r90=0.000000
piecedeleter-queue-size,scope=storj.io/storj/storagenode/pieces rmax=1.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces count=42607.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces sum=14030282805357.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces min=35291.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces avg=329295252.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces max=96749857825.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces rmin=133873.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces ravg=20437380.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces r10=139005.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces r50=149185.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces r90=715065.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces rmax=498660832.000000
piecedeleter-queue-time,scope=storj.io/storj/storagenode/pieces recent=177330.000000
DQ nodes that delete trash⦠and/or rename it to something that sounds less like trashā¦
filesmarkedfordeletion⦠terrible name but you get the idea⦠trash sounds like its not importantā¦
or one can just call them marked filesā¦
because they are not trash they are marked for deletion⦠anyways i think the problem is mostly in the naming schemeā¦
calling them marked i kinda like actually⦠because then people that donāt know wonāt understand what they are⦠and thus they will have to ask and then they will learn what they are and that they shouldnāt delete themā¦
ofc iām sure with enough time a better or more suitable name could be found⦠but that was what i could come up with off the top of my head.
@BrightSilence we noticed a second bug with our zombie segment reaper. The data Stefan deleted was very old. The zombie segment reaper is checking the creation time of the segment and simply didnāt clean up some leftovers from Stefans bucket. We fixed and executed the zombie segment reaper. Next garbage collection run should follow this weekend. I would expect that we will see another round of garbage.
The good news is we now should have finished the cleanup
