In my experience once the node is stopped whatever remains can be deleted. I have never seen files as old as an hour ever been reused after node restarts.
@Alexey
Please correct me if I am wrong so I along with other SNOs can take proper action.
@Alexey
I do not know a proper action (if it needed at all), but if you see something old as 72h itās safe to delete (the transfer is cancelled anyway from the customersā uplink).
Of course, only for temp files ![]()
checked my 54 nodes and none of them showed excessive temp files.
so doesnāt seem to be a common issue.
max was 1.8GB
temp should not contain files older than 3 day(, mine is 0 right now, when node fullā¦)
so 1.8 gb is excessive
Wow! 1.8GB of 4MB files? There must be 4-500 files! Stop the node and delete them. Files in temp folder⦠to not be confused with trash.
No need to stop the node, just delete everything older than 3 days
sounds like a storj problem rather than a me problem, also a years old node.
bothering to delete 1.8 thats worth 20$ pr TB
so recovering 0.036$ and that might be overvaluing it because.
20$ pr TB is rather high.
