No. The next payout is mainly adding the flag to your config file and double-check that without any feedback if everything works.
Ehm - the next payout is adding this flag? So i do not have to add it by myself? I already did it. Do i have to remove it?
Please, leave the option in the config. Iâm sure @littleskunk mean the flag on the satellite side.
Yea sorry bad English. I mean there is no other trick. You can only add it to the config without any feedback if it worked or not.
The only verification I can think of is the storage node logs. They would print out a warning for any config flag that couldnât be âdecryptedâ.
Hi All,
Can I just confirm whether all I need to do to enable zkrollup on my nodes is adding this to my docker config alongside my already configured wallet address?
WALLET_FEATURES=âzksync,raidenâ
i.e.:
docker run -d --restart unless-stopped -p 28967:28967
-p XXXXX:XXXXX
-e WALLET=â0xâ WALLET_FEATURES=âzksync,raidenâ
-e EMAIL=""
-e ADDRESS=""
-e BANDWIDTH=â10TBâ
-e STORAGE=â3TBâ
Cheers
If you want to pass it via command line, it should be after the rest of the run command. You can also specify it in the config.yaml file.
Thanks guys, I tried adding the below parameter to the config.yaml but after starting the container it didnât really show anything in the logs about this parameter.
operator.wallet-features: [âzksyncâ]
Then I tried again by changing my command as shown below and the container still runs but again there is no mention of the parameter in the logs. How would I know if the container is taking this change into consideration?
-p XXXXX:XXXXX
-e WALLET=â0xâŚâ
-e EMAIL=""
-e ADDRESS=""
-e BANDWIDTH=â10TBâ
-e STORAGE=â3TBâ
-e WALLET_FEATURES=âzksync,raidenâ\
âmount type=bind,source="/volume2/Storj_Node1/identity",destination=/app/identity
âmount type=bind,source="/volume2/Storj_Node1/storage",destination=/app/config
âname storjlabs-storagenode1 storjlabs/storagenode:latest
Is this the correct way to do it?
You need to add the parameter after âname storjlabs-storagenode1 storjlabs/storagenode:latest in the format:
--mount type=bind,source="/volume2/Storj_Node1/storage",destination=/app/config
--name storjlabs-storagenode1 storjlabs/storagenode:latest
--operator.wallet-features=zksync
Currently there is no feedback for the user, but this should be added to the dashboard in one of the next few releases.
