currently I’m facing huge ingoing bandwith with like 15 mbit/s by each node. The line can’t handle it and I’m running into the limit and having grafana display issues. Is there a possibility to limit the bandwith and then how?
You can set max-concurrent-requests to limit the number (but not throughput) of concurrent connections. Not a perfect solution, but as a temporary measure might be good enough.
