Error received when running below command :
sudo docker run --rm -e SETUP=“true” --mount type=bind,source="~/.local/share/storj/identity/storagenode",destination=/app/identity --mount type=bind,source=/dev/sda2,destination=/app/config --name storagenode storjlabs/storagenode:latest
docker: Error response from daemon: invalid mount config for type “bind”: invalid mount path: ‘~/.local/share/storj/identity/storagenode’ mount path must be absolute.
Craig
November 24, 2021, 8:02pm
2
My hunch is Docker needs the absolute path rather than the home (~) shortcut.
Big thanks!
So I’ve updated my command such that has the absolute path and get this error :
failed to check for file existence: stat config/config.yaml: not a directory
Alexey
November 24, 2021, 8:15pm
4
You need to mount your disk to the folder first, see How do I setup static mount via /etc/fstab for Linux? - Node Operator
Then use the mount point in your docker run command instead of /dev/sda2
Please, show result of the command:
sudo blkid
/dev/sda2: UUID=“90dafb81-7be2-4ec0-8c5a-ae8eef53b763” TYPE=“ext4” PARTUUID=“14063b45-9692-4198-9e9e-d9d11ab7a552”
Alexey
November 24, 2021, 8:25pm
6
Ok, good. At least it’s ext4.
Please, mount it to the some folder, /mnt/storj for example, then run the setup.
XXXXXXXXXXXX storjlabs/storagenode:latest "/entrypoint" 10 minutes ago Up 10 minutes 127.0.0.1:14002->14002/tcp, 0.0.0.0:28967->28967/tcp, 0.0.0.0:28967->28967/udp, :::28967->28967/tcp, :::28967->28967/udp storagenode
Although when checking my dashboard via command line, I get this :
Storage Node Dashboard ( Node Version: v1.42.4 )
ID hdflkz.vn.zljfp19
Status OFFLINE
Uptime 33m5s
Available Used Egress Ingress
Bandwidth N/A 0 B 0 B 0 B (since Nov 1)
Disk 550.00 GB 0 B
Internal 127.0.0.1:7778
External MY_PUBLIC_IP:28967
