oops, that’s definitely a bug and not intentionally. thanks. I fixed it. All sources are now updated. Thanks for the report! I should check my dashboards more carefully next time ![]()
All good, I just noticed it when I was pilfering the per node disk usage details from your dashboard to include in mine
Hi all
I’m looking into the combined dashboard and have a question about the disk free numbers:
Node dashboard shows this:
Grafana dashboard shows higher value (Free+Trash ???):
Which dashboard is wrong?
Oh I seem to see what’s happening I think The exporter see the trash as free space
Not 100% sure but when you add the values on the official dashboard it gives you the free space in exporter (approximately)
Hey guys I’m currently stuck.
I’m trying to create a graph that will display the delta of profits over 24H i seem not to be able to do it
any help will be much apprecheated
Thanks
sum(delta(storj_payout_currentMonth{type=~"payout|held",nodename=~"$node.*"}[24h])) / 100
Thanks it seems to work
Hello, i have some strange behavior for a panel:
As you can see this specific panel shows still the old names of the satellites, other panels are showing the new names, but not this panel.
Because of changes in the logs since V1.53.1 the log-exporter fails to provide parts of its data.
Here are the two files i modified to make it working again and create a new docker image.
Create a new Image
git clone https://github.com/kevinkk525/storj-log-exportercd storj-log-exporter<copying new files>- sudo docker build -t storj-log-exporter-new .
(Could take some time, be patient)
Now there should be a new (local, not from Docker Hub) container image in your list → execute
docker images
for the list.
docker-compose.yml
storj-log-exporter-new:
image: storj-log-exporter-new:latest
container_name: storj-log-exporter-new
restart: unless-stopped
user: "1000:1000"
networks:
- default
# ports:
# - 9144:9144
volumes:
- type: bind
source: <path_to_your_logfiles>
target: /app/logs
command: -config /app/config.yml
config.yml
global:
config_version: 3
input:
type: file
path: /app/logs/node.log
readall: false # Read from the beginning of the file? False means we start at the end of the file and read only new lines.
imports:
- type: grok_patterns
dir: /app/logstash-patterns-core/patterns
grok_patterns:
metrics:
- type: counter
help: Total number of deleted pieces
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecedeleter\s*delete piece sent to trash\s*\{\"Process\"\: \"storagenode\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\}'
labels:
satellite: '{{.SatelliteID}}'
url: '{{if eq .SatelliteID "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}}ap1.storj.io:7777{{else if eq .SatelliteID "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}}us1.storj.io:7777{{else if eq .SatelliteID "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}}eu1.storj.io:7777{{else if eq .SatelliteID "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"}}europe-north-1.tardigrade.io:7777{{else if eq .SatelliteID "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}}saltlake.tardigrade.io:7777{{else if eq .SatelliteID "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo"}}us2.storj.io:7777{{end}}'
- type: counter
help: Total number of failed deletes
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecedeleter\s*could not send delete piece to trash\s*\{\"Process\"\: \"storagenode\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\}'
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecedeleter\s*delete failed\s*\{\"Process\"\: \"storagenode\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\}'
labels:
- type: counter
help: Total number of uploads started
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*upload started\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"\, \"Available Space\"\: %{INT:AvailableSpace}\}'
labels:
type: '{{if eq .Action "PUT"}}usage{{else if eq .Action "PUT_REPAIR"}}repair{{else}}{{.Action}}{{end}}'
- type: counter
help: Total number of successful uploads
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*uploaded\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"\, \"Size\"\: %{INT:Size}\}'
labels:
- type: counter
help: Total number of canceled uploads
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*upload canceled\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"\, \"Size\"\: %{INT:Size}\}'
labels:
- type: counter
help: Total number of rejected uploads
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*upload rejected\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"(\, \"Size\"\: %{INT:Size})?\}'
labels:
- type: counter
help: Total number of failed uploads
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*upload failed\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"(\,\s*"error": \"%{DATA:Error}\",\s*"errorVerbose": \"%{DATA:ErrorVerbose}\")?(\, \"Size\"\: %{INT:Size})?\}'
labels:
error: '{{.Error}}'
- type: counter
help: Total number of downloads started
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*download started\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"\}'
labels:
type: '{{if eq .Action "GET"}}usage{{else if eq .Action "GET_REPAIR"}}repair{{else if eq .Action "GET_AUDIT"}}audit{{else}}{{.Action}}{{end}}'
- type: counter
help: Total number of successful downloads
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*downloaded\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"\}'
labels:
- type: counter
help: Total number of canceled downloads
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL}\s*piecestore\s*download canceled\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"\}'
labels:
- type: counter
help: Total number of failed downloads
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL:LOGLEVEL}\s*piecestore\s*download failed\s*\{\"Process\"\: \"storagenode\"\, \"Piece ID\"\: \"%{DATA:PieceID}\"\, \"Satellite ID\"\: \"%{DATA:SatelliteID}\"\, \"Action\"\: \"%{DATA:Action}\"(\,\s*"error": \"%{DATA:Error}\",\s*"errorVerbose": \"%{DATA:ErrorVerbose}\")?\}'
labels:
error: '{{if eq .Action "GET_AUDIT"}}.Error{{else}}use of closed network connection{{end}}' # workaround for all unique write tcp error messages..
- type: counter
help: Total number of loglevel messages in log
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*%{LOGLEVEL:LOGLEVEL}\s*%{DATA}\}'
labels:
loglevel: '{{.LOGLEVEL}}'
- type: counter
help: Total number of error messages in log and their type
match: '%{TIMESTAMP_ISO8601:UNWANTED}\s*ERROR\s*%{DATA:TYPE}\s*\{%{DATA}\}'
labels:
loglevel: 'ERROR'
type: '{{.TYPE}}'
server:
protocol: http
port: 9144
path: /
Hi,
I try to run dashboard , everything looks fine but no susses for logs. All grok_exporter are ignored.
HELP grok_exporter_lines_total Total number of log lines processed by grok_exporter.
TYPE grok_exporter_lines_total counter
grok_exporter_lines_total{status=“ignored”} 11487
grok_exporter_lines_total{status=“matched”} 0
Regards,
Fernando
do you have an updated config.yml for this? I’m trying to implement this on my system.
Replace every occurance of
\"Process\"
with
\"process\"
in the config.yml, it’s just a small change in the logs output to lowercase.
A good tool for the next change in the logs: https://grokdebugger.com/
Hello, I want to set up this exporter to have the maximum information possible, but I’m not sure what the default path for the node.log file should be.
Or if you need to redirect the Docker log output to a file or what needs to be done.
You should follow theese steps to redirect your logs to the location you want.
Usually logs redirected to same location where storagenode data folder is.
On linux it looks like this in config.yaml :
configures log encoding. can either be ‘console’, ‘json’, ‘pretty’, or ‘gcloudlogging’.
log.encoding: “console”
the minimum log level to log
log.level: info
can be stdout, stderr, or a filename
log.output: /app/config/node.log
Thanks!
I thought it could be executed from another host like the exporter that connects to the web interface.
Now I have it up and running, but it seems that it doesn’t collect all the data correctly. I see there’s a pull request on GitHub to address this change in the latest versions.
It would be great if @kevink could launch the combined dashboard.
My bad, the dashboard actualy exist
Hi, I have issues with the logs i get only the download fail cancel sucess srartet and the upload failed. But all the rest is empty. I changed "Process" to "process" with find and replace. Did anything change?
Hello together,
thanks alot for the Log-Exporter. I’ve been using this now almost for a year and couldn’t operate properly without it. ![]()
Do know how to make the Grafana-Dashboard accessible through the internet? This would be great, right now I can reach it only by LAN with computer:3000 for example.
Thanks and kind regards,
Hello Walter
First option is portforwarding (like a node), but this gives anyone access to your Dashboard, so not really secure.
Second option is using tunneling through SSH.
Third option would be a VPN at home, perhaps your router can handle that itself.
Hi all,
Just wondering if this is working for anyone still? I’m having an issue where the grok exporter is not matching any lines.
I have changed the log output to json. Made sure the log file is named correctly…
I’ve also tried running in docker and installing grok exporter locally with the same result.
Just looking for a confirmation, maybe it’s something I’m doing wrong.
Thank you
