Es hängt hier… bei Step 4 … warum?
This is no longer active its V2 we are on V3. https://storj.io/
Sorry… Beginner problems… :X … THANK YOU SO MUCH for your TIME to answer!!
Is there any similar way like v2 … v3 looks a bit complicated… ??
Welcome to the forum @Jussip!
May I ask where did you get the exe to install that older version ?
Well its Win GUI on windows or you can run docker, or linux, windows GUI is much easier though.
https://documentation.storj.io/setup/gui-windows
i´ve googled it… wait… there´s the link: [https://github.com/storj/storjshare-gui/releases](http://STORJ Windows GUI 64bit executable)
Hello there! I have the same problem.
Infinite connection.
public IP address.
Port 28967 is open.
Rarely writes connected and immediately disconnected
“Storage Node Dashboard” Not open
Hello @vel,
Please, remove the deprecated StorjShare it is for the v2 version of the network which was shutdown a year ago.
Please, use the installation guide for the current network: https://documentation.storj.io/
It was installed. Now deleted and it is not installed
Deleted “storj share”. Left only a “storj v3 storage node”. Dashboard doesn’t start
- Please, make sure that you generated an identity: https://documentation.storj.io/dependencies/identity
- And signed it: https://documentation.storj.io/dependencies/identity#authorize-the-identity
- Remove the
"C:\Program Files\Storj"folder - Download a latest release https://github.com/storj/storj/releases and install it. During setup you should point to the right directory with your signed identity (folder with 6 files) and to the data folder. You should have at least 550GB of free space to start.
