root@50:~# grep trash /opt/storj/data/config.yaml
# move pieces to trash upon deletion. Warning: if set to false, you risk disqualification for failed audits if a satellite database is restored from backup.
pieces.delete-to-trash: false
root@50:~# ls -lsah /opt/storj/data/storage/trash/qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa/
total 56K
5.0K drwx------ 4 storj-storagenode storj-storagenode 4 May 23 00:32 .
25K drwx------ 7 storj-storagenode storj-storagenode 8 Mar 27 22:08 ..
13K drwx------ 1026 storj-storagenode storj-storagenode 1.1K May 22 20:03 2024-05-22
13K drwx------ 1026 storj-storagenode storj-storagenode 1.1K May 23 00:34 2024-05-23
root@50:~# ps aux | grep storage | grep -v grep
storj-s+ 148901 8.3 3.9 2498260 334440 ? Ssl May18 517:08 /opt/storj/bin/storagenode run --config-dir /opt/storj/data
storj-s+ 149444 0.0 0.4 1243992 36276 ? Ssl May19 0:51 /opt/storj/bin/storagenode-updater run --config-dir /opt/storj/data --binary-location /opt/storj/bin/storagenode
Please review my message first
Node restarted at 18 of may, new folders in trash still generated 22.05 & 23.05
This is broken for now =)
I believe that feature flag has been removed that time, but I sent your report to the team.
I forgot version in my report - v1.104.5
Please what is the status of this?
Is pieces.delete-to-trash: false supposed to be working? (not working for me, v1.105.4)
It should be. Do you see that it’s not?
Please measure the size of these folders. The high level - the trash folder as a whole.
Then check, that you do not have any non-empty subfolders with date later than your change.
P.S. also, I guess that this change would stop processing the trash. So, likely you would need to remove subfolders after 7 days manually…
I did not change it, i have pieces.delete-to-trash: false set up since the node’s beginning, never changed it.
The trash folder is 3.7 GB
the content goes like this:
There is an open issue for this: Config option pieces.delete-to-trash: false looks to be ignored · Issue #7012 · storj/storj · GitHub
according to the link above, if I set pieces.enable-lazy-filewalker: false will it stop moving to trash folder?
You may try it. It should work, but also I thought that this option should work too even for lazy, so we need a confirmation.
you mean from me/users or from developers?
I can see pieces going to trash, although as I said I have it turned off for months:
I set pieces.enable-lazy-filewalker: false yesterday (+ restart), and today new trash was created again:
Did you make sure there are no leading or trailing spaces in that config line ?
From the fellow Storage Node Operators, yes. Only the SNO can truly confirm is it working or not. The developers may check that only if there would be a bug report on GitHub. Right now it’s not confirmed fully, so your help is appreciated.
Thank you for the confirmation!
I added your feedback to the issue.
A good read.
