Do you know how to correct that?
as i said:
If you use IPSec, you can try Shrewsoft VPN client, this has an option to only route traffic that is targetted to the remote network through the VPN
However, I can only provide the ShrewSoft instructions from german supplier AVM (which are in german but with screenshots).
https://avm.de/service/vpn/praxis-tipps/vpn-verbindung-zur-fritzbox-unter-windows-einrichten-fritzfernzugang/
Maybe the general steps help you…
How did it go?
I have something similar build on hc2, the difference is that I have openvpn server on the node(for maintenance) and telemetry data is sent over tls mqtt
Did you have any luck deploying this configuration?
How can you configure the Storj Node container to utilize a separate connection from that of the SSH server and Zabbix agent? Is this some sort of VPN tunneling technique? Or is it just a matter of connecting the Storj Node to a separate docker-network?
This is something I’ve been wondering about for some time now, and I remembered that you had diagrammed this, so I thought maybe you could explain how something like this might work.
