Lots of error codes, and negligible traffic
Greetings. I setup my storagenode 2 days ago, and I thought all was fine. The setup script found the right key in less that one minute, all 6 files were there, and no error upon creating and running the docker container in windows. From yesterday until today, I began to realize that something was off. Literally not even a byte of data was transferred, and the docker container logs command showed nothing. I thought this meant that the vetting hadn’t taken place. I went to storjnet.info, and input my node ID. That when I realised that there were a lot of errors. It only showed the latest one. The logs still showed nothing, and I didn’t know what the error meant. I’m hoping that this all makes sense so far. The latest error is this: rpc error: code = Unknown desc = node error: transport error: context deadline exceeded. Thanks for reading my long post, and I’m hoping you can help me. I have attached a screenshot if that helps a bit. Thanks for all your help in advance.
UPDATE: I rechecked the logs and every couple of minutes, the error rpc error: code = PermissionDenied desc = info requested from untrusted peer would display. In the first two seconds of the container starting, it says Voucher request denied. Vetting process not yet complete. There also doesn’t seem to be any vetting taking place. It also failed to do the periodic version check due to a read udp i/o timeout. here are the logs up until now.
2019-08-26T01:09:53.559Z        INFO    Configuration loaded from: /app/config/config.yaml
2019-08-26T01:09:53.572Z        INFO    Operator email: 1001545@isd535.org
2019-08-26T01:09:53.572Z        INFO    operator wallet: 0xFc24BAE92eCc3E0D5f06999Ef4BA3f05b32DD484
2019-08-26T01:09:54.317Z        INFO    version running on version v0.17.0
2019-08-26T01:09:54.437Z        INFO    db.migration    No Version
2019-08-26T01:09:54.437Z        INFO    db.migration.0  Initial setup
2019-08-26T01:09:54.439Z        INFO    db.migration.1  Network Wipe #2
2019-08-26T01:09:54.439Z        INFO    db.migration.2  Add tracking of deletion failures.
2019-08-26T01:09:54.439Z        INFO    db.migration.3  Add vouchersDB for storing and retrieving vouchers.
2019-08-26T01:09:54.440Z        INFO    db.migration.4  Add index on pieceinfo expireation
2019-08-26T01:09:54.440Z        INFO    db.migration.5  Partial Network Wipe - Tardigrade Satellites
2019-08-26T01:09:54.440Z        INFO    db.migration.6  Add creation date.
2019-08-26T01:09:54.441Z        INFO    db.migration.7  Drop certificate table.
2019-08-26T01:09:54.441Z        INFO    db.migration.8  Drop old used serials and remove pieceinfo_deletion_failed index.
2019-08-26T01:09:54.442Z        INFO    db.migration.9  Add order limit table.
2019-08-26T01:09:54.442Z        INFO    db.migration.10 Optimize index usage.
2019-08-26T01:09:54.442Z        INFO    db.migration.11 Create bandwidth_usage_rollup table.
2019-08-26T01:09:54.442Z        INFO    db.migration.12 Clear Tables from Alpha data
2019-08-26T01:09:54.443Z        INFO    db.migration.13 Free Storagenodes from trash data
2019-08-26T01:09:54.444Z        INFO    db.migration.14 Free Storagenodes from orphaned tmp data
2019-08-26T01:09:54.446Z        INFO    Node 1DZHvXaXCpTmUckjeDLJmb5G8iCDDBUJwoEdviu885ZKv3w5ko started
2019-08-26T01:09:54.446Z        INFO    Public server started on [::]:28967
2019-08-26T01:09:54.446Z        INFO    Private server started on 127.0.0.1:7778
2019-08-26T01:09:54.448Z        INFO    vouchers        Checking vouchers
2019-08-26T01:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T01:09:54.459Z        INFO    vouchers        Requesting voucher      {"satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2019-08-26T01:09:54.459Z        INFO    vouchers        Requesting voucher      {"satellite": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW"}
2019-08-26T01:09:54.459Z        INFO    vouchers        Requesting voucher      {"satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2019-08-26T01:09:54.459Z        INFO    vouchers        Requesting voucher      {"satellite": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2019-08-26T01:09:54.467Z        INFO    piecestore:monitor      Remaining Bandwidth     {"bytes": 20000000000000}
2019-08-26T01:09:54.485Z        INFO    version running on version v0.17.0
2019-08-26T01:09:54.862Z        INFO    vouchers        Voucher request denied. Vetting process not yet complete
2019-08-26T01:09:55.140Z        INFO    vouchers        Voucher request denied. Vetting process not yet complete
2019-08-26T01:09:55.352Z        INFO    vouchers        Voucher request denied. Vetting process not yet complete
2019-08-26T01:09:56.179Z        INFO    vouchers        Voucher received        {"satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2019-08-26T01:10:02.113Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:16:22.446Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:21:30.114Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:24:54.754Z        INFO    version running on version v0.17.0
2019-08-26T01:27:30.889Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:34:06.847Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:39:52.890Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:39:54.727Z        INFO    version running on version v0.17.0
2019-08-26T01:45:10.280Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:50:24.988Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T01:54:54.679Z        INFO    version running on version v0.17.0
2019-08-26T01:56:27.977Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:01:49.111Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:07:02.331Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T02:09:54.711Z        INFO    version running on version v0.17.0
2019-08-26T02:12:17.346Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:17:35.803Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:22:43.506Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:24:54.722Z        INFO    version running on version v0.17.0
2019-08-26T02:28:08.507Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:33:35.120Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:38:46.392Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:39:54.713Z        INFO    version running on version v0.17.0
2019-08-26T02:45:11.036Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:52:29.444Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T02:54:54.712Z        INFO    version running on version v0.17.0
2019-08-26T02:57:47.678Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:03:10.925Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:08:22.653Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T03:09:54.718Z        INFO    version running on version v0.17.0
2019-08-26T03:14:32.763Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:19:44.174Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:24:54.691Z        INFO    version running on version v0.17.0
2019-08-26T03:25:00.187Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:30:06.273Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:35:25.265Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:39:54.727Z        INFO    version running on version v0.17.0
2019-08-26T03:40:39.301Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:45:51.552Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:51:08.449Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T03:54:54.721Z        INFO    version running on version v0.17.0
2019-08-26T03:56:17.149Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:01:39.277Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:06:46.533Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T04:09:54.740Z        INFO    version running on version v0.17.0
2019-08-26T04:11:58.259Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:18:05.603Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:23:15.955Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:24:54.683Z        INFO    version running on version v0.17.0
2019-08-26T04:28:26.350Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:33:42.939Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:38:51.473Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:39:54.711Z        INFO    version running on version v0.17.0
2019-08-26T04:44:08.480Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:49:19.539Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:54:31.541Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T04:54:54.704Z        INFO    version running on version v0.17.0
2019-08-26T04:59:46.497Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:05:02.013Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T05:09:54.705Z        INFO    version running on version v0.17.0
2019-08-26T05:10:16.146Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:16:24.611Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:21:42.948Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:24:54.693Z        INFO    version running on version v0.17.0
2019-08-26T05:26:57.872Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:33:56.083Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:39:10.922Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:40:04.447Z        ERROR   version Failed to do periodic version check: Get https://version.alpha.storj.io: dial tcp: lookup version.alpha.storj.io on 192.168.65.1:53: read udp 172.17.0.3:39010->192.168.65.1:53: i/o timeout
2019-08-26T05:48:00.201Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:53:10.057Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T05:54:54.717Z        INFO    version running on version v0.17.0
2019-08-26T05:58:24.642Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:03:43.159Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T06:09:54.683Z        INFO    version running on version v0.17.0
2019-08-26T06:09:56.761Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:16:19.859Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:21:39.854Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:24:54.713Z        INFO    version running on version v0.17.0
2019-08-26T06:26:55.388Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:32:07.487Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:37:21.971Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:39:54.716Z        INFO    version running on version v0.17.0
2019-08-26T06:42:35.918Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:47:50.080Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:52:57.494Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T06:54:54.702Z        INFO    version running on version v0.17.0
2019-08-26T06:58:15.443Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:04:12.034Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:09:20.286Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T07:09:54.684Z        INFO    version running on version v0.17.0
2019-08-26T07:14:43.283Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:20:07.495Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:24:54.738Z        INFO    version running on version v0.17.0
2019-08-26T07:26:26.759Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:31:37.399Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:36:55.413Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:39:54.696Z        INFO    version running on version v0.17.0
2019-08-26T07:42:02.244Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:47:48.225Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:53:45.375Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T07:54:54.733Z        INFO    version running on version v0.17.0
2019-08-26T07:59:06.378Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:04:21.525Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:09:30.843Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:09:54.447Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T08:09:54.713Z        INFO    version running on version v0.17.0
2019-08-26T08:14:42.250Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:20:53.521Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:24:54.722Z        INFO    version running on version v0.17.0
2019-08-26T08:27:00.018Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:32:13.638Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:37:21.910Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:39:54.709Z        INFO    version running on version v0.17.0
2019-08-26T08:42:35.137Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:49:02.900Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:54:31.250Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T08:54:54.704Z        INFO    version running on version v0.17.0
2019-08-26T08:59:46.683Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:05:03.982Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T09:09:54.718Z        INFO    version running on version v0.17.0
2019-08-26T09:10:19.945Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:15:43.590Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:20:49.613Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:24:54.729Z        INFO    version running on version v0.17.0
2019-08-26T09:25:56.601Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:32:09.001Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:37:17.897Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:39:54.761Z        INFO    version running on version v0.17.0
2019-08-26T09:42:38.351Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:47:47.988Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:53:08.851Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T09:54:54.721Z        INFO    version running on version v0.17.0
2019-08-26T09:58:30.669Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:03:39.450Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:09:03.012Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T10:09:54.712Z        INFO    version running on version v0.17.0
2019-08-26T10:14:21.525Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:15:13.827Z        INFO    piecestore      upload started  {"Piece ID": "73N4QXXRQBTKRXAQEAWKA2H5QYHZXIWYUY47OW2WX2LLNEFPUPUA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT"}
2019-08-26T10:15:14.089Z        INFO    piecestore      uploaded        {"Piece ID": "73N4QXXRQBTKRXAQEAWKA2H5QYHZXIWYUY47OW2WX2LLNEFPUPUA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT"}
2019-08-26T10:15:43.423Z        INFO    piecestore      upload started  {"Piece ID": "TVNRXAJF5J4OZTWTEITSHGXKSCXEI6AUO2GXESIIU7BZQWMHRMNA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT"}
2019-08-26T10:15:43.459Z        INFO    piecestore      uploaded        {"Piece ID": "TVNRXAJF5J4OZTWTEITSHGXKSCXEI6AUO2GXESIIU7BZQWMHRMNA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT"}
2019-08-26T10:19:24.265Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:20:26.558Z        INFO    piecestore      upload started  {"Piece ID": "5FSFU2AGE3PZYPCG6PDEQHXALJZNA35OX7PTV3CA46UFYGGYQRFA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT"}
2019-08-26T10:20:26.597Z        INFO    piecestore      uploaded        {"Piece ID": "5FSFU2AGE3PZYPCG6PDEQHXALJZNA35OX7PTV3CA46UFYGGYQRFA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT"}
2019-08-26T10:24:41.456Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:24:54.722Z        INFO    version running on version v0.17.0
2019-08-26T10:29:50.729Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:36:35.300Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:39:54.691Z        INFO    version running on version v0.17.0
2019-08-26T10:41:45.491Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:46:55.518Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:52:57.069Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T10:54:54.734Z        INFO    version running on version v0.17.0
2019-08-26T10:58:04.636Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:03:13.056Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:08:33.842Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:09:54.446Z        INFO    piecestore:orderssender.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S    sending  {"count": 3}
2019-08-26T11:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T11:09:54.690Z        INFO    version running on version v0.17.0
2019-08-26T11:09:54.752Z        INFO    piecestore:orderssender.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S    finished
2019-08-26T11:13:41.607Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:19:06.830Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:24:29.618Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:24:54.727Z        INFO    version running on version v0.17.0
2019-08-26T11:30:29.934Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:35:44.742Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:39:54.705Z        INFO    version running on version v0.17.0
2019-08-26T11:41:48.337Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:47:03.592Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:52:25.361Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T11:54:54.711Z        INFO    version running on version v0.17.0
2019-08-26T11:57:34.454Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:02:39.217Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:07:54.743Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:09:54.447Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T12:09:54.700Z        INFO    version running on version v0.17.0
2019-08-26T12:13:36.655Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:18:47.095Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:24:03.252Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:24:54.714Z        INFO    version running on version v0.17.0
2019-08-26T12:29:19.171Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:30:59.177Z        INFO    piecestore      download started        {"Piece ID": "TVNRXAJF5J4OZTWTEITSHGXKSCXEI6AUO2GXESIIU7BZQWMHRMNA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT"}
2019-08-26T12:30:59.238Z        INFO    piecestore      downloaded      {"Piece ID": "TVNRXAJF5J4OZTWTEITSHGXKSCXEI6AUO2GXESIIU7BZQWMHRMNA", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT"}
2019-08-26T12:34:31.306Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:39:44.307Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:39:54.711Z        INFO    version running on version v0.17.0
2019-08-26T12:44:50.476Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:50:18.517Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T12:54:54.728Z        INFO    version running on version v0.17.0
2019-08-26T12:55:40.443Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:00:46.506Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:06:42.889Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:09:54.446Z        INFO    piecestore:orderssender.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S    sending  {"count": 1}
2019-08-26T13:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T13:09:54.698Z        INFO    version running on version v0.17.0
2019-08-26T13:09:54.708Z        INFO    piecestore:orderssender.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S    finished
2019-08-26T13:11:59.230Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:17:02.316Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:22:52.644Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:24:54.744Z        INFO    version running on version v0.17.0
2019-08-26T13:28:04.347Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:33:24.121Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:39:20.592Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:39:54.703Z        INFO    version running on version v0.17.0
2019-08-26T13:44:29.861Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:49:43.043Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T13:54:54.739Z        INFO    version running on version v0.17.0
2019-08-26T13:55:03.465Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T14:00:21.071Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T14:06:34.604Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T14:09:54.446Z        INFO    bandwidth       Performing bandwidth usage rollups
2019-08-26T14:09:54.690Z        INFO    version running on version v0.17.0
2019-08-26T14:12:10.388Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T14:17:22.068Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T14:22:28.305Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
2019-08-26T14:24:54.718Z        INFO    version running on version v0.17.0
2019-08-26T14:28:18.711Z        ERROR   server  rpc error: code = PermissionDenied desc = info requested from untrusted peer
Thanks again for all your help.
The periodic version check error can be ignored.
How many neighbors do you have? Have you checked if your ports are open just to make sure you can receive incoming traffic? yougetsignal.com
Thanks for your reply. Neighbor count is at 148. The ports test open at times, as well as closed. They are open only 2/3 of the time. I clicked the check button 6 times, and it tested open 4 times, and closed 2 times. I still sometimes recieve data. below is a screenshot of my port forwarding config. DDNS is also configured and seems to work by pinging it. I recieved the correct public IP address. I just recieved 10MBs worth of blobs, so I don’t know why I am getting the errors. Again, any help is much appreciated.
Hey @Antonios-P!
Some windows users were having firewall issues after the docker update, please try adding a new rule for the port 28967:
Windows Defender Firewall->Advanced Setting->Inbound Rule->New Rule->Port
I have already added the rule. I set port 28967 for inbound and outbound to have no restrictions. What would the audits look like if they were to be taking place? I don’t think any audits have happened for my node yet.
Please run powershell as admin and execute:
New-NetFirewallRule -DisplayName "Storj v3" -Direction Inbound -Protocol TCP -LocalPort 28967 -Action allow
If you have added any outgoing rule - please, remove them or disable.
Please copy the output of the commands:
docker exec -it storagenode grep -c BEGIN /app/identity/ca.cert
docker exec -it storagenode grep -c BEGIN /app/identity/identity.cert
Please, check the firewall on your router. Something sometimes blocking traffic to your node.
From 7 sent messages 2 have been ended with
Error: rpc error: code = Unknown desc = kademlia error: node error: transport error: context deadline exceeded
It could be an antivirus or something like that
I do not have any “after-market” antivirus, and I have turned off Windows Defender.
The output of docker exec -it storagenode grep -c BEGIN /app/identity/ca.cert puts out 2, and the output of docker exec -it storagenode grep -c BEGIN /app/identity/identity.cert puts out 3. I have turned off the firewall in the router. We’ll see if that helps. I deleted the outbound rule in the windows firewall as well.
I would recommend to turn on the windows defender back. It will be enabled by Windows sooner or later anyway.
Just the allowance rule is enough.
Now you node is responding on every request and a little bit faster than before
I see you have an asus router. I was having issues with my Asus router in the beginning because it was dropping connections left and right. Might be useful to check the router logs. I ended up having to factory reset the router to fix it. Reboot and update did nothing.
nothing suspicious shows up in the router logs. I am still getting the same errors as before, just not as frequently. There are more info notices before an error occurs. should vetting have happened already? It hasn’t for me.
The errors you’re seeing are not a problem. Periodically being down or the port being detected as closed is. Can I suggest you set up uptimerobot.com to monitor the port and see how bad the issue is? Despite not seeing issues on your router logs, a reset might still help as well.
I have left the uptimerobot dashboard and monitor active for 2 hours now. It says it was up 100% of the time. Anything else to do? UPDATE: Now Yougetsignal says that 28967 is always open. Does this solve my problem?
if your dashboard shows you online and the port is open, then yes, that should solve your problem. Though I would advice installing the uptime robot app on your phone and setting up alerts so you will know immediately when the issue returns. Can’t hurt to keep an eye on it.
I already did that. Thanks everyone for helping.
