Dear Community,
We have setup a node with 1.5 PiB of storage. It has been running for 1 week, but the downloaded data is only 50 GB. Our bandwidth is 250 Mbit/s.
How can we improve the download and disk usage rate?
Best regards
Bjorn
Dear Community,
Best regards
Bjorn
Here’s what to expect:
Thank you, but how do we improve the download rate. 50 GB after one week of operation seems a bit low to us.
Have you setup 1.5 PB for one Node? My last knowledge is that there is a maximum of 24 TB per Node.
You can check this link as well:
Actually you can’t improve or increase the disk usage. STORJ is meant for low bandwith usage, CPU usage to run also on like Raspberry Pi’s.
But you can get other opinions as well.
You need more internet connections
There are OS’s that allow you to create large pools
to fill this space you need something lika 50-100 external ips from ditterent \24 space other you wont get lot of data, and then 250 mbit is too small.
Would it be Ubuntu or Windows?
Thanks! Is there a provider with this kind of service?
Just one example
Hello BHK,
quick rundown of a few points going only very surface level:
TLDR: Till you are vetted 50GB in a week sounds about right. Once I got vetted and all problems solved I am at about 50-55 Ingress per day.
1.5 PiB? IMO you have to wait about 300 years to fill that storage ![]()
5TB/y is optimistic, 1500/5 = 300.
