Malformed request: static website and cyberduck can't connect
Hello, can you help me with the configuration with this bucket, I have problems linking it to a domain. http://storj.maivall.com
I have to clarify, that it is not the first container that I configure.
But with this specifically I have problems, as well as to connect via CyberDuck.
Ticket: https://supportdcs.storj.io/hc/en-us/requests/17376
Hi @maitret
Your DNS isn’t configured correctly. The TXT record for txt-storj.maivall.com should return the storj-root: and the storj-access: records, but I only see the storj-root…
Type Domain Name TTL Record
TXT txt-storj.maivall.com 5 min storj-root:storj.maivall.com
Also the storj-root result should be the bucket name (+ /prefix if required)
It’s already corrected, it was a detail in the dns
Thank you very much :slight_smile:
