Manual Installation STORJ-Node
Hello guys,
when a new node is setup it is downloaded with
-e SETPUP=true
. The STORJ-File can be just downloaded:
grafik
Can this STORJ-Node be manually installed? Sometimes the installation through github seems laggy and it cancels, because the token-time runs out.
Thanks and kind regards,
Looks like the routing and peering to github is just bad. Unfortunately it is completely out of my influence and only 23,8 KB/s.
I may suggest to use a VPN to download it :person_shrugging:
