Maximum number of simultaneous transfers
I installed a new node on another location and the config.yaml seems a little different, how do I change the maximum number of simultaneous transfers ? I found something but Im not sure this is the right thing…
number of concurrent transfers per graceful exit worker
graceful-exit.num-concurrent-transfers: 1
typically you don’t need to change that anymore.
The option " graceful-exit.num-concurrent-transfers: 1" however is something different.
Its looks like they removed it from the config but I assume you can re add it, with
how many concurrent requests are allowed, before uploads are rejected.
storage2.max-concurrent-requests: 100
Please comment out any line in your config still referring to maximum concurrency. We no longer need this. Please do not modify any lines related to graceful exit though.
so there is no other way that we could increase the node traffic ?
Only to invite more customers
I finally started to hit my concurrency limit of 43 today, pretty hard. I will comment out this line.
What is this tool? It look good.
Custom Grafana dashboard. You can build it from here: Visual Dashboard - Grafana Mon: 24hr Docker log > Telegraf > InfluxDB
