May I know if storj work with Qnap TS219p ii? Are there any specific update to make before making it a node? I’m a newbie.
Does storj also work with any other nas, eg synology?
Hello @Ataraxist ,
If your model support Container Station - then - yes. Enable Container Station and ssh and follow guide for CLI: CLI Install - Storj
The docker will be installed with Container Station automatically.
I just recommend to generate and sign an identity on other PC/Mac: Identity - Storj then transfer it to the QNAP, because on QNAP it could take a week.
For the Synology the advise is the same - enable/install Container Station and ssh to your NAS and setup a node and the updater.
