Memory consuption
Add a timeout to stop commands
This will give it up to 5 minutes. Works with restart as well.
I created a separate topic for the too many requests error here
ok, thanks
try how it works
I have the same problem again my ram is used at 5.28 GB on 5.72GB
please post screenshot of docker exec -it storagenode top -m
Here is
Please, copy output of the docker stats command.
Also I see that your storage node have a lot of dashboard process. Try to kill all with:
pkill -f dashboard
@Lucas How exactly do you run the dashboard?
Nothing has changed for the RAM !
I run with this command : docker exec -it storagenode /app/dashboard.sh
dashboard processed is gone, now please restart container docker restart storage node -t 300
And monitor memory consumption.
What is the purpose of this command?
Dashboard can produce higth memory consuption, a lot of dashboards can produce a lot of memory consuption like on your side, see this topic.
Purpose of docker restart storage node -t 300 is drop all consumed memory after you kill all dashboard processes with pkill -f dashboard
I have an error
Capture
typo
docker restart -t 300 storagenode
Thanks! @Alexey
yep, i make a typo with container name.
Ok it’s good at the moment, I’ll let you know if there is a new rise.
Thank you !
