Hi All.
Trying to migrate from 1 host to another. I copied the identity folder along with the data but when I try to run on the new host I receive this error in the logs …
2020-09-05T00:42:17.061+0100 FATAL Unrecoverable error {“error”: “Error creating tables for master database on storagenode: migrate: no such table: main.order_archive_\n\tstorj.io/storj/private/migrate.SQL.Run:274\n\tstorj.io/storj/private/migrate.(*Migration).Run.func1:179\n\tstorj.io/storj/private/dbutil/txutil.withTxOnce:75\n\tstorj.io/storj/private/dbutil/txutil.WithTx:36\n\tstorj.io/storj/private/migrate.(*Migration).Run:178\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:386\n\tmain.cmdRun:184\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”, “errorVerbose”: “Error creating tables for master database on storagenode: migrate: no such table: main.order_archive_\n\tstorj.io/storj/private/migrate.SQL.Run:274\n\tstorj.io/storj/private/migrate.(*Migration).Run.func1:179\n\tstorj.io/storj/private/dbutil/txutil.withTxOnce:75\n\tstorj.io/storj/private/dbutil/txutil.WithTx:36\n\tstorj.io/storj/private/migrate.(*Migration).Run:178\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:386\n\tmain.cmdRun:184\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n\tmain.cmdRun:186\n\tstorj.io/private/process.cleanup.func1.4:353\n\tstorj.io/private/process.cleanup.func1:371\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:66\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Any idea what would cause this issue?
