One of my nodes hard drives currently has a lot of bad sectors, and it looks like the drive is dying.
long story short the drive is really fragmented, so it was estimating over a week to transfer which in windows time would probably be even longer, so I figured the node would be dq’ed before it transfers.
I thought that I could write a small program that transfers the small directories one at a time and then put a NTFS junction link in it’s place.
I noticed that my audit score basically dropped 4% in a few hours.
and in the log file, there were lots of errors stating that storj couldn’t read/write files to these NTFS junction files because they were on another hard drive which seems really stupid that it can’t do this.
so my question is, how do you normally migrate a drive if you need to when the storj is really big e.g. 10TB+.
And it’s transferred about 5TB so far so even if I stop my node now to move the rest, it’s probably still going to DQ me due to how long it’s going to take to transfer, so I guess I just bite the bullet and kill the node without a graceful exit?
it’s really unfortunate that it can’t read/write through NTFS junction links, since the Windows filesystem API’s can handle move/copy commands regardless of whether there is a NTFS junction link in place, as the entire reason they are there is for scenarios like this.
with the amount of fragmentation the drive has, windows estimates 7 days to transfer it all, but my experience with windows estimated transfer time is a complete lie, and will usually take double the amount of time it says.
If your audit score is getting bad so quickly you might want to stop the node and transfer the files while it is not running.
On Windows you should use Robocopy with multithreading:
If you have bad sectors you should look at Robocopy retry and wait switches and adjust the default settings: robocopy | Microsoft Learn
Usually the fastest ways to copy whole disks is not to try copying them file by file, instead copying the whole disk images. There are many tools for that, for example the open source ntfsclone. They are faster because they don’t attempt to locate each file separately, every single one in a different location, instead they just scan the whole file system to look which blocks are used by the file system, then copy the blocks sequentially. Sequental reads are fast. You could expect the whole copy to proceed at speeds like 100 MB/s or more, which should be good enough to make it in a single day or two with the node turned off and not risk disqualification.
However, the complicating factor are the bad blocks. I don’t know which of those tools will cope with them in a satisfactory way.
You may use a generic partition cloning program as well, like Partition Magic or other similar tools.
You may also use Ubuntu Live USB stick to boot into Linux to use ntfsclone.
I shut down the node as soon as I posted, but it looks like I got DQ’ed anyway as enough audits failed. well lesson learnt for next time, don’t use NTFS folder junction links to try keep the node running while transferring.
Sorry to read that. Yes, junction links rarely works like expected, too many conditions. For example - the SYSTEM user could not access it because of permissions issue, or just not supported if they points to another disk (seems your case).
I’m not sure that symlinks in Linux would work too.
