Hi Awesome Alexey,
Please help me understand these lines
2024-08-28T14:00:17Z WARN collector unable to delete piece {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Piece ID": "Q3OYAIYASRULOYQ745F7XNW7PFUKSGOUVVCYWWAEUOX6O7NB52IA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:124\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:340\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:320\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:359\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:112\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:68\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-28T14:00:17Z WARN collector unable to delete piece {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Piece ID": "DHN3ETASGX3YFLZISG7BF6MJEOHIJ24ONJRSNZ7E4EURAKJZ64EA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:124\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:340\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:320\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:359\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:112\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:68\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-28T14:00:17Z INFO collector no expired pieces to collect {"Process": "storagenode"}
2024-08-28T14:00:17Z INFO collector expired pieces collection completed {"Process": "storagenode", "count": 4504}
Unable to delete is fairly common now. I copied them to give you an idea on what was before those “collect” lines.
I want you to look at the last 2 lines about no expired pieces then the next line says ... collection completed "count" : 4504".
This is totally contradicting the 2nd to last line about NO EXPIRED PIECES. If there are no expired pieces then what does 4504 denote ?
