Can you tell me if there is a mobile application for monitoring the nodes Storj?
Подскажите есть ли мобильное приложение для мониторинга нод Storj?
There isn’t but you can open your dashboard remotely to check its status.
I read this. The question is not about that.
my recommendation and what I will prob be doing is running the command and having the output emailed to me.
something like this…
There is no specific mobile application, but you can configure uptimerobot.com to notify you if your port become closed: How do I check my node when I'm away from my machine? - Node Operator
Такого мобильного приложения сейчас нет, но вы можете использовать How do I check my node when I'm away from my machine? - Node Operator для получения уведомлений если порт перестанет быть доступным и How to remote access the web dashboard - Node Operator для подключения к dashboard.
