Hi,
Is it possible move running docker nodes to portainer ?
there are any tutorial ?
thx
daki82
2
Google says its an graphical overlay for docker? you just install it after docker.
Alexey
4
You may add it as a stack: Add a new stack - Portainer Documentation
The example of docker-compose.yaml you can see there:
ptC7H12
5
Yes, it is just a graphical interface for docker. When you install portainer you will see all your dockers
Alexey
7
doesn’t matter, It can work on both.
