Hi! Was wondering what you guys use to monitor your nodes. I use a telegram bot @storjnodemonitor_bot, bit it looks like it is no longer notifying when a node goes down since the last update of 1.55.1.
My own nodejs app installed into the node and a dedicated server to ping the node from outside.
I can:
Update dns (cloudflare api)
Ping node (from dedicated server)
Check docker status\report (docker commands)
Create disk report (smartmontools package)
Mail notification\report (mailgun api)
Then i check storj multinode dashboard for a general overview.
Also all the node are SSH enabled with a set of ready to use scripts.
I manage 30+ remote nodes.
