Alfred
March 27, 2021, 7:10pm
1
Hi mates,
since some days I got problems with my node on a raspberry pi.
Its crashing all the time, after only few minutes up.
here is my log:
sudo docker logs --tail 20 storagenode
crypto/tls.(*cipherSuiteTLS13).extract(0x10704f0, 0x0, 0x0, 0x0, 0x182af40, 0x20, 0x20, 0x0, 0x182af40, 0x20)
/usr/local/go/src/crypto/tls/key_schedule.go:66 +0x78
crypto/tls.(*serverHandshakeStateTLS13).sendServerFinished(0x1ef6d08, 0x0, 0x0)
/usr/local/go/src/crypto/tls/handshake_server_tls13.go:658 +0x16c
crypto/tls.(*serverHandshakeStateTLS13).handshake(0x1ef6d08, 0x1992600, 0x0)
/usr/local/go/src/crypto/tls/handshake_server_tls13.go:62 +0xbc
crypto/tls.(*Conn).serverHandshake(0x1ce1600, 0x1, 0x275101)
/usr/local/go/src/crypto/tls/handshake_server.go:50 +0x68
crypto/tls.(*Conn).Handshake(0x1ce1600, 0x0, 0x0)
/usr/local/go/src/crypto/tls/conn.go:1362 +0xd0
crypto/tls.(*Conn).Read(0x1ce1600, 0x1bdf000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
/usr/local/go/src/crypto/tls/conn.go:1239 +0x48
bufio.(*Scanner).Scan(0x1ccf900, 0x0)
/usr/local/go/src/bufio/scan.go:214 +0x88
storj.io/drpc/drpcwire.(*Reader ).ReadPacket(0x208f960, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x40000000, …)
/go/pkg/mod/storj.io/drpc@v0.0.16/drpcwire/transport.go:121 +0xc4
storj.io/drpc/drpcmanager.(*Manager ).manageReader(0x1ba2210)
/go/pkg/mod/storj.io/drpc@v0.0.16/drpcmanager/manager.go:288 +0xec
created by storj.io/drpc/drpcmanager.NewWithOptions
/go/pkg/mod/storj.io/drpc@v0.0.16/drpcmanager/manager.go:78 +0x340
Can anyone help me out?
Thanks!
Alex
SGC
March 27, 2021, 8:06pm
2
there should be a lot more if it was actually connected…
often the node will continually reset until connected…
https://documentation.storj.io/dependencies/port-forwarding
so i would guess portforwarding, firewall blocking ports, or ip address miss configuration.
i would have hoped i could read the log message… but looks very connection related…
best advice i can offer…
not always right tho… these logs are kinda terrible for rookies…
i’ve been around a year and i can barely make sense of it…
Alexey
March 28, 2021, 5:25am
3
I would recommend:
Stop and remove the container
docker rm storagenode
Prune images
docker image rm storjlabs/storagenode:latest
Pull a new version
docker pull storjlabs/storagenode:latest
Run the node with all your parameters back.
Alfred
March 28, 2021, 12:51pm
4
Hi Guys,
Thanks for your Help so far.
No ist seems running, but my certificate is not loaded properly. How can I use, / Import, /authorize my old cert File? I do Not get that…
Please Help
Alex
Alexey
March 28, 2021, 12:53pm
5
The part of the logs shows me that there is some more deep problem, on OS or docker level. The stack trace is unusual for the unloaded identity.
Have you performed steps which I suggested?
Alfred
6
It says TLS Peer certificate Verifikation Error
Alfred
March 28, 2021, 12:54pm
7
Yes i Re installed the hole system
Alexey
8
Ok, then get an authorization token from there: https://registration.storj.io/ and sign your identity: Identity - Storj
Alfred
March 28, 2021, 1:00pm
10
I have the token already. as I understand I Need the old certificate and Re authorize it gain. Ist that correct? The command identity authorize storagenode … Ist not working in my Machine…
Alexey
March 28, 2021, 1:02pm
11
It should work. What identity binary you have used? What is your current platform where you tried to authorize the identity? What’s the error?
SGC
March 28, 2021, 2:36pm
12
did you do the grep thing that should say 2 and 3 rather than 1 and 2
i have on occasion had nodes where i could have sworn i did sign the identity, but then hadn’t…
under confirming identity.
i know it doesn’t exactly solve anything… but it does confirm if the identity was signed… ofc it also has to be in the right location for node or whatever one is trying to do…
Alfred
March 28, 2021, 3:15pm
13
Yes, in the end i copied the 2 Files to the root directory and did this signing grep command again.
It returned 2 for both. No it works or seems to.
Thanks to both of you!!
Alex
