Yes, normally you should do so. However, if you would use a latest tag now, your docker will download a 64 bit version, since at the moment for the ARM64 only an aarch64 image available, it will update to it and your node may stop to work, because this latest image is broken.
In the next release you can use latest again, the image for ARM64 is fixed there. Until then, I would recommend using this explicit tag:
Thanks @Alexey I really appreciate. I just wanted to double check!
Hi @Alexey quick question. How do we KNOW when the latest tag will work for the ARM64?
Thanks
Edu
When the Windows nodes will be updated on 100%. You can check this https://version.storj.io/
When the cursor will be all “FFF”, then all Windows nodes are updated, then the docker image would be published and should be available under the latest tag.
Hi @Alexey - Do you know if there is any problem with this image: https://hub.docker.com/layers/storjlabs/storagenode/2413a9a0d-v1.18.1-go1.15.5-arm32v6/images/sha256-b14d30b849799c21042d5d15bae6c1e3987c6c593a0808abfe41ae47aa80df37?context=explore
I got an error on my node:
2021-01-20T22:47:01.075757047Z 2021-01-20T22:47:01.075Z INFO Operator email {"Address": "eduardo.sequeira.hernandez@gmail.com"}
2021-01-20T22:47:01.075877453Z 2021-01-20T22:47:01.075Z INFO Operator wallet {"Address": "0xE26b4761DD50CfE22D8eF632bc229d17D09DF5B8"}
2021-01-20T22:47:01.692311306Z 2021-01-20T22:47:01.691Z INFO Telemetry enabled {"instance ID": "17rUiCzph4fnAGUWwCuUaidxU4o2xGBtnvTyWzwfEbSiQ3Wk8B"}
2021-01-20T22:47:01.810199640Z 2021-01-20T22:47:01.809Z INFO db.migration Database Version {"version": 46}
2021-01-20T22:47:02.784343077Z 2021-01-20T22:47:02.783Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-01-20T22:47:03.384257614Z 2021-01-20T22:47:03.383Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2021-01-20T22:47:03.384977199Z 2021-01-20T22:47:03.384Z INFO bandwidth Performing bandwidth usage rollups
2021-01-20T22:47:03.386577368Z 2021-01-20T22:47:03.386Z INFO Node 17rUiCzph4fnAGUWwCuUaidxU4o2xGBtnvTyWzwfEbSiQ3Wk8B started
2021-01-20T22:47:03.386698089Z 2021-01-20T22:47:03.386Z INFO Public server started on [::]:28967
2021-01-20T22:47:03.387188083Z 2021-01-20T22:47:03.386Z INFO Private server started on 127.0.0.1:7778
2021-01-20T22:47:03.390294755Z 2021-01-20T22:47:03.389Z INFO trust Scheduling next refresh {"after": "8h11m21.352416947s"}
2021-01-20T22:47:03.584168614Z 2021-01-20T22:47:03.583Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:03.646220637Z 2021-01-20T22:47:03.645Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 1, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.102.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.102.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:03.665106441Z 2021-01-20T22:47:03.664Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:03.806366346Z 2021-01-20T22:47:03.805Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.117.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.117.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:04.024275511Z 2021-01-20T22:47:04.022Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 1, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:04.147538435Z 2021-01-20T22:47:04.146Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:04.826908104Z 2021-01-20T22:47:04.826Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 2, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:04.892853697Z 2021-01-20T22:47:04.892Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 2, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.102.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.102.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:05.052883776Z 2021-01-20T22:47:05.052Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 2, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:05.226920857Z 2021-01-20T22:47:05.226Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 2, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.117.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.117.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:05.560822926Z 2021-01-20T22:47:05.560Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 2, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:05.737830643Z 2021-01-20T22:47:05.736Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 2, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:06.992215273Z 2021-01-20T22:47:06.991Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 3, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:07.053876780Z 2021-01-20T22:47:07.053Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 3, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.112.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.112.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:07.324062637Z 2021-01-20T22:47:07.323Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 3, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.124.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:07.615137443Z 2021-01-20T22:47:07.614Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 3, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.117.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.117.0.10:53: no such host\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-01-20T22:47:08.025126012Z 2021-01-20T22:47:08.024Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 3, "error": "ping satellite error: check-in network error: failed to resolve IP from address: storjnodedu.ddns.net:28967, err: lookup storjnodedu.ddns.net on 10.122.0.10:53: no such host", "errorVerbose": "ping satellite error: check-in network error: failed to resolve IP from address:
it looks like it tels that storjnodedu.ddns.net not exist or something like that
did you updated your ddns subscription?
Good point, let me take a look. I did not update the subscription but let me take a look.
i made ping request to your addres, looks like host not exist, or you made some writing error?
Ping request could not find host storjnodedu.ddns.net. Please check the name and try again.
The DNS expired today and I was busy to check my email alert. I just purchased the annual subscription and I will set up a reminder to do it next year. I feel so dumb I was down for about 8 hours or so.
Thanks for the help.
can hapen to everyone, glad i can help.
