Hi,
this is the error I receive when running the logs:
Error: read config/config.yaml: input/output error
Usage:
/app/storagenode run [flags]
Help would be much appreciated.
Thanks in advance
Hi,
Usage:
Thanks in advance
Check your disk with fsck
and also check the USB cables, USB ports.
Jupp that is mostly disk related, when it is gone. In addition to above also check (if its attached by USB) if some powersavings Stuff is enabled for it.
Thank you. Would the command be fsck and then the disk directory? Because its telling me that it will do damage on the disk?
