My node is offline from the first moment
Oh ok… that is independent of whether I already have NoIp, right? And if so, any VPN provider with port forward that you recommend please?
Hello @SoloRei ,
Did you restart the storagenode service after changing the config file? You can do this from the Services applet or from the elevated (with administrator’s rights) PowerShell:
Restart-Service storagenode
If you did restart of the storagenode service, but the node is still offline - please, check the WAN IP on the Status page of your router, it should be the same as on yougetsignal, if it’s not match - then you definitely behind the ISP’s NAT.
If so, you still have a few options:
  • call to your current ISP and ask for public IP, it could be dynamic, but must be a public (WAN IP will match IP on yougetsignal). You can say that you need an access to your security IP cam from anywhere, to do not explain Storj;
  • switch ISP to one who offer a public IP;
  • use VPN services with port forwarding option such as portmap.io, ngrok, PIA, AirVPN, PureVPN, etc.
English~
Thank you all for your answers, I investigated and it turns out that my ISP does not allow ports to be opened… so I changed ISP for one that does allow ports to open and now the Node is online; one more time thank you all for your answers (@Vadim @will.topping @Skyblockpro1 @daschmidt @Alexey ) Thak you so much.
Spanish~
Gracias a todos por sus respuestas, investigué y resulta que mi ISP no permite que se abran los puertos… así que cambié el ISP por uno que sí permite que se abran los puertos y ahora el Nodo está en línea; una vez más gracias a todos por sus respuestas (@Vadim @will.topping @Skyblockpro1 @daschmidt @Alexey ) Muchas gracias de verdad.
