I finished installing my node following these steps but from the first moment it was offline, reading I realized that this happens because it does not open port 28967 (which I had not done), so I continued to open it but the node is still offline.
I am not an expert but I would really appreciate if you can help me, my node has been offline for 32 hours.
Spanish~
Hola, cree mi nodo guiándome con este video
Termine de instalar mi nodo siguiendo esos pasos pero desde el primer momento estaba offline, leyendo me di cuenta que esto pasa por no abrir el puerto 28967 (lo cual no había hecho), entonces proseguí a abrirlo (creo) pero el nodo sigue offline.
Yo no soy un experto pero gradecería mucho si pueden ayudarme, mi nodo lleva 32 horas fuera de linea.
You need to put not ip but name that you registered. Like something.noip.com:28967 or what you registered. Olso check port open that your port is realy opened. Sometime routers also make some problems that it realy not make nat as writen or need open firewall port additinaly
I already write the host name but it is still offline, even deactivate all security of my router and it is still offline. I would attach more images but the forum tells me that new users can only post one image per topic or reply.
I also want to thank you for trying to help me, I am quite new to all this and somewhat clumsy, but I really thank you.
