Hi.
I setup my node many months ago and I turn it off, I went ahead and turn it on now, and it’s offline.
The node starts, I can access the internal portal but it does say “offline”
at yougetsignal, the port is open…
any idea of what I can check?
Hi.
You should also check your logs for errors. Assuming you use a DDNS service, I would check that the hostname hasn’t expired with your provider. I know that Storj has implemented a system that disqualifies nodes that have been offline for more than 30 days. That was added 22 days ago, but I am not sure if it took effect immediately. If your node has been offline for months, it is very likely you will have to start over.
