Hello. My node is offline. Help me, please.
Welcome to the forum @Quort!
Port 28967 is closed. IP-addresses is different. Use Windows 10 and NO-IP DUC v4.1.1.
You are using No-IP then it shouldn’t matter. Show me your docker run command and remove any personal info from it.
I use windows gui version.
What does config.yaml have for this?
contact.external-address:
If you mean the WAN IP and public IP are different, then you have only three options:
- switch the ISP to one, who offer the public IP instead of “gray”;
- talk with your ISP and ask them how to obtain a public IP;
- use the VPN services with port forwarding option such as PIA, portmap.io, ngrok, PureVPN, etc.
Have you setup port forwarding?
I think it’s solved in the Russian thread with the same question
