My node wont start
2024-08-03T21:55:09Z    INFO    Anonymized tracing enabled
2024-08-03T21:55:09Z    INFO    Operator email  {"Address": "jgb211@icloud.com"}
2024-08-03T21:55:09Z    INFO    Operator wallet {"Address": "0x8faB05cAd4eF723eEB5Ca5878f19218618ff6100"}
2024-08-03T21:55:09Z    ERROR   failure during run      {"error": "Error opening database on storagenode: database: bandwidth opening file \"D:\\\\bandwidth.db\" failed: disk I/O error: There is not enough space on the disk.\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabaseWithStat:407\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:384\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:379\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:354\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:319\n\tmain.cmdRun:67\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "errorVerbose": "Error opening database on storagenode: database: bandwidth opening file \"D:\\\\bandwidth.db\" failed: disk I/O error: There is not enough space on the disk.\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabaseWithStat:407\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:384\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:379\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:354\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:319\n\tmain.cmdRun:67\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n\tmain.cmdRun:69\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-03T21:55:09Z    FATAL   Unrecoverable error     {"error": "Error opening database on storagenode: database: bandwidth opening file \"D:\\\\bandwidth.db\" failed: disk I/O error: There is not enough space on the disk.\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabaseWithStat:407\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:384\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:379\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:354\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:319\n\tmain.cmdRun:67\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "errorVerbose": "Error opening database on storagenode: database: bandwidth opening file \"D:\\\\bandwidth.db\" failed: disk I/O error: There is not enough space on the disk.\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabaseWithStat:407\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:384\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:379\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:354\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:319\n\tmain.cmdRun:67\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n\tmain.cmdRun:69\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
As shown in the log, there isn’t any space on your drive.
thanks so why did the software keep adding data to create this problem, i allocated 12 TB. it should have stopped, is there a solution to this
You allocated 12TB out of how large an HDD?
You’re not giving us a lot of information to go with here…
Out of a total of 12.7
here are something new,
2024-08-04T00:28:17Z    INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker completed      {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "bytesDeleted": 0, "numKeysDeleted": 0, "Process": "storagenode"}
2024-08-04T00:28:17Z    INFO    lazyfilewalker.trash-cleanup-filewalker subprocess finished successfully        {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-04T00:28:17Z    INFO    pieces:trash    emptying trash finished {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "872.0157ms"}
2024-08-04T00:28:17Z    INFO    pieces:trash    emptying trash started  {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-04T00:28:17Z    INFO    lazyfilewalker.trash-cleanup-filewalker starting subprocess     {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-04T00:28:17Z    INFO    lazyfilewalker.trash-cleanup-filewalker subprocess started      {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-04T00:28:17Z    WARN    collector       unable to delete piece  {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "RRI4JMDL6AYRMKBPML3M5RVNDZW3QOLGZF3W4QA2KICGTWJ5R54Q", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:124\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:290\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:270\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:356\n\tstorj.io/storj/storagenode/collector.(*Service).Collect.func1:88\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).GetExpired:71\n\tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:579\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:87\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:65\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:61\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:44\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:17Z    INFO    lazyfilewalker.trash-cleanup-filewalker.subprocess      trash-filewalker started        {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "dateBefore": "2024-07-28T00:28:17Z"}
2024-08-04T00:28:17Z    WARN    collector       unable to delete piece  {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "BU4AI42GF2LQUYMK3KJYZP7XIPKDYR6TNMPF6HABGAKXC4NNQZXA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:124\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:290\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:270\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:356\n\tstorj.io/storj/storagenode/collector.(*Service).Collect.func1:88\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).GetExpired:71\n\tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:579\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:87\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:65\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:61\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:44\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:17Z    WARN    collector       unable to delete piece  {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "NSKJOU3E7EV6VHT3GDK6E5OCOJVAMATOFLGXJBK6IWNYBXNXYB3Q", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:124\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:290\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:270\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:356\n\tstorj.io/storj/storagenode/collector.(*Service).Collect.func1:88\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).GetExpired:71\n\tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:579\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:87\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:65\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:61\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:44\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:17Z    INFO    Stop/Shutdown request received.
2024-08-04T00:28:17Z    INFO    contact:service context cancelled       {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-08-04T00:28:17Z    ERROR   contact:service ping satellite failed   {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:203\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:17Z    INFO    contact:service context cancelled       {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-04T00:28:17Z    ERROR   contact:service ping satellite failed   {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:203\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:17Z    INFO    contact:service context cancelled       {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-04T00:28:17Z    ERROR   contact:service ping satellite failed   {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: context canceled", "errorVerbose": "ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:203\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:157\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:17Z    INFO    contact:service context cancelled       {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-04T00:28:17Z    ERROR   nodestats:cache Get pricing-model/join date failed      {"error": "context canceled"}
2024-08-04T00:28:17Z    INFO    lazyfilewalker.trash-cleanup-filewalker subprocess exited with status   {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": 1, "error": "exit status 1"}
2024-08-04T00:28:17Z    ERROR   pieces:trash    emptying trash failed   {"error": "pieces error: lazyfilewalker: exit status 1", "errorVerbose": "pieces error: lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:187\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:426\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2024-08-04T00:28:17Z    WARN    collector       unable to delete piece  {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "QNR4TI3H4BCSLSK37FTJ5DIWKGEIG6TSAMUYI3S5EGLOBRX46WIA", "error": "pieces error: filestore error: file does not exist", "errorVerbose": "pieces error: filestore error: file does not exist\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).Stat:124\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).pieceSizes:290\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).DeleteWithStorageFormat:270\n\tstorj.io/storj/storagenode/pieces.(*Store).DeleteSkipV0:356\n\tstorj.io/storj/storagenode/collector.(*Service).Collect.func1:88\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).GetExpired:71\n\tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:579\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:87\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:65\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:61\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:44\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:17Z    ERROR   collector       error during collecting pieces:         {"error": "pieces error: context canceled", "errorVerbose": "pieces error: context canceled\n\tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:581\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:87\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:65\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/storj/storagenode/collector.(*Service).Run:61\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:44\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    INFO    lazyfilewalker.used-space-filewalker    subprocess exited with status   {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": 1, "error": "exit status 1"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": true, "error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:715\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    INFO    pieces  used-space-filewalker started   {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-04T00:28:18Z    INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-08-04T00:28:18Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "error": "context canceled"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:715\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    INFO    pieces  used-space-filewalker started   {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-04T00:28:18Z    INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-08-04T00:28:18Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:715\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    INFO    pieces  used-space-filewalker started   {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-04T00:28:18Z    INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-08-04T00:28:18Z    ERROR   lazyfilewalker.used-space-filewalker    failed to start subprocess      {"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "error": "context canceled"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:130\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:715\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    ERROR   pieces  used-space-filewalker failed    {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    ERROR   piecestore:cache        error getting current used space:       {"error": "filewalker: context canceled; filewalker: context canceled; filewalker: context canceled; filewalker: context canceled", "errorVerbose": "group:\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78\n--- filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:724\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    INFO    lazyfilewalker.gc-filewalker    subprocess exited with status   {"satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "status": 1, "error": "exit status 1"}
2024-08-04T00:28:18Z    ERROR   pieces  lazyfilewalker failed   {"error": "lazyfilewalker: exit status 1", "errorVerbose": "lazyfilewalker: exit status 1\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkSatellitePiecesToTrash:160\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:565\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:379\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:265\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-08-04T00:28:18Z    ERROR   filewalker      failed to get progress from database
2024-08-04T00:28:18Z    ERROR   retain  retain pieces failed    {"cachePath": "C:\\Program Files\\Storj\\Storage Node/retain", "error": "retain: filewalker: context canceled", "errorVerbose": "retain: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePiecesToTrash:181\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePiecesToTrash:572\n\tstorj.io/storj/storagenode/retain.(*Service).retainPieces:379\n\tstorj.io/storj/storagenode/retain.(*Service).Run.func2:265\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Your disk is too slow (or you use a VM), so you need to disable the lazy mode in the config.yaml file:
save the config and restart the node.
The used space on the dashboard would be updated when the filewalker would finish the scan for all trusted satellites.
Screenshot 2024-08-04 070052what do i do about this
Why you reinstalling? It never solves any problem, related to a filewalker and databases.
But you may check logs, why is it complaining.
I was reinstalling it trying to resolve an issue. My nodes been down for two days and I can’t seem to get it to start probably by now. I already lost the node so you guys get to keep the money.
Did you find a reason in your logs, why it wont install?
just were are these logs located
Storagenode won’t add new data if less than 5GB of space is remaining.
Something else has filled your disk.
maybe your main operating system drive (C:) filled up.
