Hello today my rpi node stopped working anything change i check the ports and they are open if i use opensignal to see if the port is open it says its closed but i have not changed anything I think its related with the ports but not sure. What do you think?
If i check the dashboard it says its offline
Here i leave the logs
2021-03-09T08:07:20.483Z ERROR contact:service ping satellite failed {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 1, “error”: “ping satellite error: failed to dial storage node (ID: 12p8vXhGUUoL5p3Gw7vi68VfZ3D9hgdWniSY22sDVf1E8uTedBv) at address gerard-dupre.ddns.net:28967: rpc: dial tcp 81.60.186.37:28967: i/o timeout”, “errorVerbose”: “ping satellite error: failed to dial storage node (ID: 12p8vXhGUUoL5p3Gw7vi68VfZ3D9hgdWniSY22sDVf1E8uTedBv) at address gerard-dupre.ddns.net:28967: rpc: dial tcp 81.60.186.37:28967: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
