My Storage Node Dashboard Indicates My Node Is Down
For some reason, the dashboard shows that my node is down. I checked everything. The service is running. My ports are opened. My identity key and cert are intact and point to the correct path. I tried reinstalling Storjnode on my Windows again but the dashboard still shows my node is down. Is it the dashboard is down and not my node? Cuz I can heard my hard disk is running.
i would think you have not configured your windows firewall , (just for quick test) try to disable windows firewall , stop storagenode service, launch it again
and come back here to tell us the result
Yes Port 28967 is allowed to go through my windows firewall for both TCP and UDP, so I don’t think it’s a firewall issue.
I’m more concerned about the dashboard. While I can see that it is offline, how come my node ID is missing, the storagenode version is missing and my monthly bandwidth and disk space used are not showing too? Even my total disk space of 10TB has been changed to 1.00B only. Is this normal? I’ve been a node operator for more than 3 years, surely the stats should be more than 0 in every category.
This is usually mean that node is restarting or stopped and you see a cached version in your browser.
Please check your logs: How do I check my logs? - Storj Node Operator Docs
Sorry I’m reposting my query here as I realised I didn’t categorise my post earlier and it was placed under the Uncategorised topic.
For some reason, the dashboard shows my node is down. I checked everything. The service is running. My ports are opened. My identity key and cert are intact and pointed to the correct path. I tried reinstalling Storagenode on my Windows again but the dashboard still shows my node is down. My Windows firewall has been configured too and port 28967 is allowed to pass through both TCP and UDP.
Moreover I noticed my node ID is missing, the storagenode version is not showing and my monthly bandwidth and disk space used are showing 0. Even my total disk space of 10TB has been changed to 1.00B only. Is this normal? I’ve been a node operator for more than 3 years, surely the stats should be more than 0 in every category. Please help!
I clicked on the link and followed the instruction to check my logs, so what should I be looking for? And what should I be doing next to get my dashboard working?
Sorry I’m tech idiot. I only know how to download the storagenode installer, follow the steps and run it on Windows. The rest is automatic. I rely very much on the dashboard to get the status of my bandwidth and the disk space used.
Edit - additional comment: Regarding the cached version you mentioned earlier, how is it that my cached version shows zero activities and 1.00B when all the while my disk space allocated was 10TB? Shouldn’t the cached version show some values in all the categories since it has been running for more than 3 years?
It caches only layout, not values.
Just post 20 last lines from your logs here between two new lines with three backticks like this:
log lines here
Please make sure that storagenode service is running either with the Services applet or from the elevated PowerShell:
Get-Service sstoragenode*
Here are the info from my logs. I also checked that my storagenode service is running.
2022-12-26T17:03:41.621+0800 INFO piecestore downloaded {“Piece ID”: “EICZQJIISISCW22TBHNNOMWQOH52KOZAKDXEROMKECV6MMFZRJ2Q”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”:
“GET_REPAIR”}
2022-12-26T17:03:41.696+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
j.io/storj/storagenode/storagenodedb.(*bandwidthDB).getSummary:171\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Summary:113\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:52\n
\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:731\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func6:673\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Dow
nload:694\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experime
nt.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcc
tx.(*Tracker).track:52”}
2022-12-26T17:03:41.698+0800 INFO piecestore downloaded {“Piece ID”: “7YISTXRCHYWJ5EHB27SWSWN2EDBMAYYYIFPNGKTXTTBCS6D7VPZQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”:
“GET”}
2022-12-26T17:03:42.246+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:731\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:445\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:220
\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC
:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52”}
2022-12-26T17:03:42.246+0800 INFO piecestore uploaded {“Piece ID”: “OBAVGBNL53CA5WNYIIBNXLB73OPWQDIYQRMRDJXK3FE7JY4IUNZQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: "
PUT", “Size”: 2319360}
2022-12-26T17:03:42.617+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
2022-12-26T17:03:42.617+0800 INFO piecestore uploaded {“Piece ID”: “YKSAXOGL7G6MLBNWI22Y3RFIUBG42KMJKRPDVTTYYC57R6XXQQCQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: "
PUT", “Size”: 3072}
2022-12-26T17:03:44.146+0800 INFO piecestore download started {“Piece ID”: “ME3A7IU7PYJ64B77I6GMIZO6444YLOPVH4ASOFA4OMORHOWHMK6A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Ac
tion”: “GET”}
2022-12-26T17:03:44.498+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:731\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func6:670\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Dow
2022-12-26T17:03:44.498+0800 INFO piecestore downloaded {“Piece ID”: “ME3A7IU7PYJ64B77I6GMIZO6444YLOPVH4ASOFA4OMORHOWHMK6A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”:
“GET”}
2022-12-26T17:03:44.576+0800 INFO piecestore upload started {“Piece ID”: “EER24CYPVQNYW2VO36H72VWBZ444VQZCSAOMBSIHVK3O55Y7UHIQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Acti
on”: “PUT”, “Available Space”: 1362688088576}
2022-12-26T17:03:44.837+0800 INFO piecestore download started {“Piece ID”: “BDNCTN6BBTKLDXWOFRUUAS3XHTNSXEF6LQLBUASPE44UUVYKT6AA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Ac
tion”: “GET”}
2022-12-26T17:03:45.071+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
2022-12-26T17:03:45.071+0800 INFO piecestore downloaded {“Piece ID”: “BDNCTN6BBTKLDXWOFRUUAS3XHTNSXEF6LQLBUASPE44UUVYKT6AA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”:
“GET”}
2022-12-26T17:03:45.290+0800 INFO piecestore upload started {“Piece ID”: “KXVCHMMBROWPXGMMRRXII7VSM6Q4JQ6RHU22JNLPWCKVZ2BSMW3Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Acti
2022-12-26T17:03:45.554+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
2022-12-26T17:03:45.555+0800 INFO piecestore uploaded {“Piece ID”: “KXVCHMMBROWPXGMMRRXII7VSM6Q4JQ6RHU22JNLPWCKVZ2BSMW3Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: "
PUT", “Size”: 2048}
2022-12-26T17:03:45.841+0800 INFO piecestore download started {“Piece ID”: “R5AJAKMWGHR6DOQ4QMFXA24V4JVMMZYT7WMQI7PGJQ46VCGYUZQA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Ac
tion”: “GET”}
2022-12-26T17:03:46.082+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
2022-12-26T17:03:46.082+0800 INFO piecestore downloaded {“Piece ID”: “R5AJAKMWGHR6DOQ4QMFXA24V4JVMMZYT7WMQI7PGJQ46VCGYUZQA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”:
“GET”}
2022-12-26T17:03:46.140+0800 INFO piecestore download started {“Piece ID”: “BDNCTN6BBTKLDXWOFRUUAS3XHTNSXEF6LQLBUASPE44UUVYKT6AA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Ac
tion”: “GET”}
2022-12-26T17:03:46.165+0800 INFO piecestore download started {“Piece ID”: “BDNCTN6BBTKLDXWOFRUUAS3XHTNSXEF6LQLBUASPE44UUVYKT6AA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Ac
tion”: “GET”}
2022-12-26T17:03:46.221+0800 INFO piecestore upload started {“Piece ID”: “QUXUFG5GOCWCU4Z7LOW7WWDN4YHBQABADI3WCIUFEPZG3XT3XI3A”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Acti
on”: “PUT”, “Available Space”: 1362688086016}
2022-12-26T17:03:46.227+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
2022-12-26T17:03:46.227+0800 INFO piecestore downloaded {“Piece ID”: “BDNCTN6BBTKLDXWOFRUUAS3XHTNSXEF6LQLBUASPE44UUVYKT6AA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”:
“GET”}
2022-12-26T17:03:46.284+0800 ERROR piecestore failed to add bandwidth usage {“error”: “bandwidthdb: database disk image is malformed”, “errorVerbose”: “bandwidthdb: database disk image is malformed\n\tstor
2022-12-26T17:03:46.284+0800 INFO piecestore downloaded {“Piece ID”: “BDNCTN6BBTKLDXWOFRUUAS3XHTNSXEF6LQLBUASPE44UUVYKT6AA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”:
“GET”}
Let me know if these are the info you need as I’m not sure whether I did it correctly or not.
  • But first of all, check your disk for errors
Search on this forum (top right corner) :
  • because this database is corrupted and you need to fix it
Thank you! It works.
And also @Alexey too for guiding me to resolve this issue.
