Hi,
My Storage Node (Raspberry Pi) is hosted on my mother’s house (and I don’t live there).
On saturday (July, 4th), the server has been shutdown and my mother can’t tell me if she did something wrong or not (maybe she powered off the outlet? she doesn’t know).
Any way, I just saw that today, the server is up again (I can’t reach my mother and I think when I’ll get her, she will tell me that she doesn’t know :/).
Anyway, I would need your help to:
- how can I know if this was due to a power outage? Maybe in the logs but I really don’t know where to look…
- If it wasn’t due to a “physical” power outage, where and how should I investigate to find the real cause?
- should I delete my node now and set it up again to avoid being disqualified when the DQ will be activated? My node is quite recent and I shoudn’t lose a lot of money (less than $2 held amount)
- I tried to check the audits with the following command (storagenode5 is my storage node name) (sorry I made a screenshot because the actual command is modified by the website):
but I received the error: “Invalid numeric literal at line 1, column 10”. How can I fix the command?
Thank you so much for your help!
