My suspension score for two satellites is 99.98 and 99.99% for us-centrail1 and asia-east respectively
My suspension score for two satellites is 99.98 and 99.99% for us-centrail1 and asia-east respectively.
When I ran the following command on power it gave me the following output.
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell https://aka.ms/pscore6
PS C:\Users\dhiwa> sls GET_AUDIT "C:\Program Files\Storj\Storage Node\storagenode.log" | sls failed
C:\Program Files\Storj\Storage Node\storagenode.log:567740:2020-10-18T04:46:39.674+0545 ERROR   piecestore      download
failed  {"Piece ID": "GDOQVC7LQC4HFWT6DUPYC64QQNTUQNXBDP2JYHVKUCPQUVCXLOJQ", "Satellite ID":
"12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "error": "order created too long ago:
OrderCreation 2020-10-17 21:58:53.68244913 +0000 UTC < SystemClock 2020-10-18 04:46:39.6732358 +0545 +0545
m=+31511.748025101", "errorVerbose": "order created too long ago: OrderCreation 2020-10-17 21:58:53.68244913 +0000 UTC
< SystemClock 2020-10-18 04:46:39.6732358 +0545 +0545 m=+31511.748025101\n\tstorj.io/common/rpc/rpcstatus.Errorf:87\n\t
storj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:45\n\tstorj.io/storj/storagenode/piecestore.(*Endpoi
nt).Download:461\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:1004\n\tstorj.io/drpc/drpcmux.(*Mux).Hand
leRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:56\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111
\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drp
c/drpcctx.(*Tracker).track:51"}
C:\Program Files\Storj\Storage Node\storagenode.log:735092:2020-10-21T05:36:28.500+0545 ERROR   piecestore      download
failed  {"Piece ID": "YFFGRITZPDXG7YNKK7YM6X5HR7IUXMH5QMACSIHQSA2HNH5I44UA", "Satellite ID":
"1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Action": "GET_AUDIT", "error": "pieces error: filestore error:
unable to open \"E:\\\\Storj Data\\\\blobs\\\\pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa\\\\yf\\\\fgritzpdxg7
ynkk7ym6x5hr7iuxmh5qmacsihqsa2hnh5i44ua.sj1\": The request could not be performed because of an I/O device error.",
"errorVerbose": "pieces error: filestore error: unable to open \"E:\\\\Storj Data\\\\blobs\\\\pmw6tvzmf2jv6giyybmmvl4o2
ahqlaldsaeha4yx74n5aaaaaaaa\\\\yf\\\\fgritzpdxg7ynkk7ym6x5hr7iuxmh5qmacsihqsa2hnh5i44ua.sj1\": The request could not
be performed because of an I/O device error.\n\tstorj.io/storj/storage/filestore.(*Dir).Open:279\n\tstorj.io/storj/stor
age/filestore.(*blobStore).Open:71\n\tstorj.io/storj/storagenode/pieces.(*Store).Reader:257\n\tstorj.io/storj/storageno
de/piecestore.(*Endpoint).Download:501\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:1004\n\tstorj.io/dr
pc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:56\n\tstorj.io/drpc/drpcserver.(
*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.fu
nc2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
C:\Program Files\Storj\Storage Node\storagenode.log:735365:2020-10-21T06:52:10.259+0545 ERROR   piecestore      download
failed  {"Piece ID": "LJBB7YTBBPWXKEAUH2ZBWZHVPUTLUHKWKJUNAMLKDUWBQMKUNF2A", "Satellite ID":
"12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT", "error": "pieces error: filestore error:
unable to open \"E:\\\\Storj Data\\\\blobs\\\\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\\\\lj\\\\bb7ytbbpwxk
eauh2zbwzhvputluhkwkjunamlkduwbqmkunf2a.sj1\": The request could not be performed because of an I/O device error.",
"errorVerbose": "pieces error: filestore error: unable to open \"E:\\\\Storj Data\\\\blobs\\\\ukfu6bhbboxilvt7jrwlqk7y2
tapb5d2r2tsmj2sjxvw5qaaaaaa\\\\lj\\\\bb7ytbbpwxkeauh2zbwzhvputluhkwkjunamlkduwbqmkunf2a.sj1\": The request could not
C:\Program Files\Storj\Storage Node\storagenode.log:735388:2020-10-21T06:57:58.661+0545 ERROR   piecestore      download
failed  {"Piece ID": "VEQRBE43MOVUK2V6AYHIEMNISAST7NP5VEEXCAEUCHBRU6OCOX6A", "Satellite ID":
"121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_AUDIT", "error": "pieces error: filestore error:
unable to open \"E:\\\\Storj Data\\\\blobs\\\\qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa\\\\ve\\\\qrbe43movuk
2v6ayhiemnisast7np5veexcaeuchbru6ocox6a.sj1\": The request could not be performed because of an I/O device error.",
"errorVerbose": "pieces error: filestore error: unable to open \"E:\\\\Storj Data\\\\blobs\\\\qstuylguhrn2ozjv4h2c6xpxy
kd622gtgurhql2k7k75wqaaaaaa\\\\ve\\\\qrbe43movuk2v6ayhiemnisast7np5veexcaeuchbru6ocox6a.sj1\": The request could not
PS C:\Users\dhiwa>
the question is that should I worry about something?
like getting disqualified on the satellites?
If your failing any kinda audits this is a problem, The error with I/O device error is not a good thing. So yes you should look into this asap before you do get DQed.
but my audits are 100%. Just the suspension rates are declining to 99.98 and 99.99%.
Yes that is to help you and give you time to figure out the problem…If your drive is failing, your node is no longer getting anymore data its only getting audits and if someone downloads from it. So I would either keep a close eye on it if it keeps falling then there is a real issue. If you see the error file not found then its a real issue.
how would I find the error?
Is there any command to find that on command prompt or Powershell?
I think your already using the command that should show it.
I am no coder or programmer, please help me find my error!
I just noticed that your log is showing old dates do you have an updated log? In windows you can just goto the storagenode.log file and search inside notepad it much easier.
The file is approximately 200 MB. Only the picture file format is supported. How should I send you this file?
As I said in your ticket - please, stop the storagenode, and perform the chkdsk /f e:\, then install https://www.timesynctool.com/ and sync your clocks, then start the storagenode back and check your logs: https://documentation.storj.io/resources/faq/check-logs
The other errors you can check with this article:
