Need A Brief Guide How To Migrate To Hashstore
Hello everyone, it has been quite some time since I was last active here, and it appears that Hashstore has now become widely adopted. I noticed the main discussion thread, but it is rather long and I cannot go through it in detail at the moment.
I would appreciate a brief guide on how to migrate my existing nodes to Hashstore. I plan to test the migration on a single node first.
Thank you in advance.
Migration will be done automatically by storj. So no need to do anything if you are not looking for adventure.
My man, you’re like right-next-door to the instructions…
…and you have time to wait for someone else to summarize for you… but don’t have time to read the instructions everyone else has been using for months? :face_with_raised_eyebrow:
No problem. here is very short summary: Just wait. You don’t need to switch.
The first post in the dedicated thread has all the instructions you need. In the log on info level, you will see migration status with 1 entry per 5-15 min. After the migration finished, you just need to clean the blobs folder, but not deleting the folder itself.
okay thanks guy. I think I just need to wait.
