I want to view the dashboard on my local device which is my smartphone connected to the same network via Wifi. I uncommented the line and replaced the 127.0.0.1 with 0.0.0.0 and allowed the inbound port for 14002 through the firewall too, but when I type my IP-address with:14002, it says something like this
This site can’t be reached
(IP Address) refused to connect
Try:
Checking the connection
ERR_CONNECTION_REFUSED
Even after doing the things you suggested me to do, I couldn’t view the dashboard on my smart phone?
It says something like this!
(IP address) refused to connect
Search google for IP address:14002
Thank You @Alexey Alexey.
The problem is solved.
Now I can view my dashboard in Local Network too.
And @baker, I didn’t get what you are trying to say. But again thank you too for your suggestion.
The problem lied in my thinking that the process of doing thing.
I actually saved the config file yesterday, and restarted the computer, thinking that it would restart the node automatically.
Now again when I run the command Restart-Service storagenode today, then the config file won’t load the settings. I have to do it on the same time.
