my endless migration is just about done also… only been copying for … nearly 14 days straight…
gone quite well tho… a bit slow…less than 2tb left so should be done tomorrow… and not a hint of issues since i got the sas drives moved to their own dedicated part of the backplane…
the 512n drives also seem to run much smoother but not really easy to test when having extensive traffic
@kevink @node1
i would trust esata 10 times more than i would usb thats for sure…
not that i’ve ever actually used it… but usb is after all created to be able to be disconnected and to support tons of different devices…
would make sense if esata was more suited for the task and more stable for storage…
ofc i would perfer SAS but look where that got me with my sata drives and sas drives mixed maybe causing me endless headaches for nearly 4 months…
sas connections tho… and sas drives… wow they are so much better its basically unfair…
like did you know that when a sas cable breaks, it doesn’t matter … because one connection breaking will only give you less bandwidth and an error…
ofc the cables costs so much extra… but basically the freaking cables have redundancy lol
if i was to recommend an enclosure i would say non usb… doesn’t hurt to have the option, but i would want something else… like esata or sff-8088 or something similar however i like 8088 for their metal brackets directly on the print boards and on the cables… thus you can basically trip over the damn thing and it will just floor you…
100€ for 4 x 3.5" thats hard to beat… ofc it does look like the esata only supports 3gbits … which should be fine… i got 3 drives running on an old sata controller on my mobo… to my surprise it actually supports 6TB drives and thus most likely should do even 16TB drives… its freaking 10 years old …
so yeah i think the 8TB limit is bs most likely… maybe a sales tactic to sell something more expensive… ofc i cannot promise it… but i would almost bet on it…
there was a 2tb limit… now there is no limit… speed will most likely be the next limiting factor… the hdds will become so large you cannot move the data out without it taking months… or weeks.
capacity wise hdd controllers that can control more than 2tb should be able to control up to 16 exabytes… or something ridiculous like that.
well my ich10 controller will do 3gbit like the esata of the “exclosure” kevink is getting… and that runs fine… and thats a 10 year old chip… and since it does 6tb it should also do like 20tb
giving me 6 more ports for hooking disk up to… sadly my 2u rack case is pretty full…
but yeah i would try and get as many disk in one enclosure as possible… because the cheaper it gets per unit… i would want esata or better external rated cables…
i would want a usb option and maybe a 1gbit nic…ofc that most likely ups the price a lot … because if you got a nic, then you have to have a processor, which needs ram and a mobo, … which ups the power requirement… and then you would need ability to control the drivves locally… and yeah… so esata might be the affordable way to go…
think ive seen some like it… but for a case to mount in 2 or 3 bay of 5½" or whatever cdrom was… but i think that was also like 300€… so yeah… HOW ABOUT NO
P.S did you know that you can almost get a 36bay DAS for that… OFC THAT WILL HAVE A BLEEP TON OF PITFALLS… so be sure you know what you are doing or be ready to start digging.
