hi all,
I recently gained a static IP from my internet service provider, so that I want this node to use a static IP for my container in the docker instead of using DDNS.
any one know how to change it? question from a newbie to docker. I have been searched around but still cannot find the answer.
p.s. my node was moving from my home to my company.
any idea?
thank you in advance, guys.
the command was in first time the configuration.
-e ADDRESS=“domain.ddns.net:28967” \
neither I can run full below command nor run in short, as this container is already in production,. got error msg:
docker: Error response from daemon: Conflict. The container name “/storagenode” is already in use by container “af52ccee50299d5a4a3d9cfxxxxxxxxxxxxxxxxxxde34a317f7342ba769”. You have to remove (or rename) that container to be able to reuse that name.
See ‘docker run --help’.
-p 28967:28967
-p 127.0.0.1:14002:14002
