Hi all, I guess I need your help… I can’t figure it out anymore. I’ve had multiple nodes in the past, but for a while I only ran one. Now I wanna setup a second one and I just can’t find the mistake.
Existing node:
Router port forwarding to the local server:
28967tcp → 28967tcp
28967udp → 28967udp
Docker compose:
ports:
- 28967:28967/tcp
- 28967:28967/udp
- 14002:14002
environment:
- ADDRESS=[my-public-ip]:28967
New node I’m trying to create:
29001tcp → 29001tcp
29001udp → 29001udp
Docker compose:
ports:
- 29001:28967/tcp
- 29001:28967/udp
- 15001:14002
environment:
- ADDRESS=[my-public-ip]:29001
I can reach the dashboard of both nodes, no problem. The dashboard of the “to be created” node says Status=offline, QUIC=Misconfigured. In the logs I get the following error:
contact:service failded PingMe request to satellite
What I also saw is the following in the logs:
INFO Public server started on [::]:7777
INFO Private server started on 127.0.0.1:7778
…while on the existing/running node it says
INFO Public server started on [::]:28967
Firewall settings on the server are also correct, I’ve even tried with the FW off.
Can someone see anything wrong with my config?
I’ll copy the docker-compose bellow:
version: "3.8"
services:
storj:
container_name: storagenode01
network_mode: bridge
restart: unless-stopped
ports:
- "29001:28967"
- "29001:28967/udp"
- 15001:14002
volumes:
- /volume1/docker/storjnode01/config/identity:/app/identity
- /volume1/storjnode01:/app/config
environment:
- WALLET=[my-wallet]
- EMAIL=[my-email]
- STORAGE=2TB
- TZ=[my-TZ]
