Ok so I did all of the instructions I was able to and one by one they all have failed. Is there any way to start over with a fresh Installation?
Yes, you should uninstall the storagenode software, remove identity and related data, then generate a new identity, sign it with a new authorization token, install the storagenode software back and configure to use this new identity and clean data location.
Please do not reuse a previous identity - it will be disqualified for losing data as soon as you bring it online. Please note - the old identity signed with a new authorization token is still the old identity, so you need to generate a new one, not copy.
Since you use an USB HDD, you should use an external power supply, the power from only one USB will be not enough in long run and your HDD likely will disconnecting from time to time.
Ok. Im gonna start this now. Wish me luck!
