I just finished up the gui for storj and followed the procedures for installing the node. On the gui it is saying that my node status is offline. I check out https://www.yougetsignal.com/tools/open-ports/?port=28967
and it is saying that my port is closed. Did I miss something?? If so, what? Please help this noob out.
For Windows GUI your configuration parameters are stored in the configuration file "%ProgramFiles%\Storj\Storage Node\config.yaml", please, use the Notepad++ to modify it, do not use the usual Notepad.
After any modifications you need to explicitly save the configuration file and restart the storagenode service either from the Services applet or from the elevated powershell:
