No bloom filter from EU1 since 2024-08-26?
Has anyone received a bloom filter in the past days from EU1 satellite?
The last one i can remember was from 2024-08-26 and is yet gone from trash folder.
AP1 sends every 3 days and US1 every 2 days, but EU1 does nothing.
EU1 trash folder from 28th is gone. Log does show last BF from 28th Aug.
$ sudo tree -L 2 /mnt/x/storagenode2/storage/trash/
β”œβ”€β”€ abforhuxbzyd35blusvrifvdwmfx4hmocsva4vmpp3rgqaaaaaaa
β”‚   └── 2024-04-20
β”œβ”€β”€ pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa
β”‚   β”œβ”€β”€ 2024-08-26
β”‚   β”œβ”€β”€ 2024-08-29
β”‚   └── 2024-09-02
β”œβ”€β”€ qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa
β”œβ”€β”€ ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa
β”‚   └── 2024-09-04
└── v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa
    └── 2024-09-02
So, it has received a BF 2024-09-02.
Accordingly logs:
$ grep retain /mnt/x/storagenode2/storagenode.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
2024-09-02T19:22:55Z    INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-22T17:59:59Z", "Filter Size": 931834, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-02T22:48:34Z    INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 14258, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 1806966, "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Duration": "3h25m38.5395111s", "Retain Status": "enabled"}
Is it possible that your node processing a BF from another satellite right now? It will process them one by one.
Unfortunately, in my case it also looks as if no filters have arrived at 10 nodes.
Node 3 is still busy with the trash cleanup but the others are β€œidle”
Trash Folder
/mnt/storj/node001_2021.10/storage/trash/
β”‚   β”œβ”€β”€ 2024-08-30
β”‚   β”œβ”€β”€ 2024-08-31
β”‚   β”œβ”€β”€ 2024-09-01
β”‚   β”œβ”€β”€ 2024-09-02
β”‚   β”œβ”€β”€ 2024-09-03
β”‚   β”œβ”€β”€ 2024-09-05
β”‚   └── 2024-09-06
β”‚   └── 2024-09-05
β”‚   └── 2024-09-04
20 directories
/mnt/storj/node002_2022.04/storage/trash/
β”‚   └── 2024-09-05
β”‚   └── 2024-09-05
β”‚   └── 2024-09-05
20 directories
/mnt/storj/node003_2023.12/storage/trash/
β”‚   β”œβ”€β”€ 2024-08-25
β”‚   β”œβ”€β”€ 2024-08-28
β”‚   └── 2024-09-05
β”‚   β”œβ”€β”€ 2024-08-27
β”‚   └── 2024-09-06
β”‚   └── 2024-09-05
    └── 2024-08-27
28 directories
/mnt/storj/node004_2024.06/storage/trash/
β”‚   └── 2024-09-05
β”‚   β”œβ”€β”€ 2024-09-04
β”‚   └── 2024-09-05
β”‚   └── 2024-09-04
18 directories
/mnt/storj/node005_2024.07/storage/trash/
β”‚   └── 2024-09-05
β”‚   └── 2024-09-05
β”‚   └── 2024-09-04
18 directories
/mnt/storj/node006_2024.07/storage/trash/
β”‚   └── 2024-09-06
β”‚   └── 2024-09-05
β”‚   └── 2024-09-04
21 directories
/mnt/storj/node007_2024.07/storage/trash/
β”‚   └── 2024-09-06
β”‚   └── 2024-09-06
β”‚   └── 2024-09-04
22 directories
/mnt/storj/node008_2024.07/storage/trash/
β”‚   └── 2024-09-06
β”‚   └── 2024-09-05
β”‚   └── 2024-09-05
19 directories
/mnt/storj/node009_2024.07/storage/trash/
β”‚   └── 2024-09-06
β”‚   └── 2024-09-05
β”‚   └── 2024-09-05
21 directories
/mnt/storj/node010_2024.07/storage/trash/
β”‚   └── 2024-09-06
β”‚   └── 2024-09-05
β”‚   └── 2024-09-05
21 directories
root@storj-chia01:~#
Could you please execute the similar command:
and then
of course, using your path or docker logs
Also
ls -l /mnt/x/storagenode2/retain/
Summary
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node002_2022.04/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node001_2021.10/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node003_2023.12/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node004_2024.06/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node005_2024.07/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node006_2024.07/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node007_2024.07/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node008_2024.07/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node009_2024.07/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
cubefan@storj-chia01:~$ cat /mnt/storj/ssd/node010_2024.07/logs/node.log | grep -E "Prepar|Move" | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
Summary
2024-09-02T06:12:04+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 11496584, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-02T06:30:00+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 322, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 138222, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "17m55.596418522s", "Retain Status": "enabled"}
2024-09-02T15:41:08+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 11496584, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-02T15:58:40+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 198, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 129606, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "17m31.939550563s", "Retain Status": "enabled"}
2024-09-03T06:36:58+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-28T17:59:59Z", "Filter Size": 7517711, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-03T07:49:10+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 286933, "Failed to delete": 2, "Pieces failed to read": 0, "Pieces count": 12980142, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "1h12m12.00217434s", "Retain Status": "enabled"}
2024-09-03T09:01:57+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 8765593, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-03T10:37:45+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 0, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 116304, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "1h35m47.8676035s", "Retain Status": "enabled"}
2024-09-03T20:28:54+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 8765593, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-03T22:09:36+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 313, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 106051, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "1h40m42.266495421s", "Retain Status": "enabled"}
2024-09-03T23:19:16+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-30T17:59:59Z", "Filter Size": 197291, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-03T23:21:32+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 3192, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 342548, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "2m16.125789636s", "Retain Status": "enabled"}
2024-09-04T00:54:13+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 5011391, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-04T02:29:40+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 165, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 103857, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "1h35m26.508260355s", "Retain Status": "enabled"}
2024-09-04T13:14:53+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 5011391, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-04T14:51:00+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 0, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 98924, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "1h36m6.344949391s", "Retain Status": "enabled"}
2024-09-05T00:24:37+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-30T17:59:59Z", "Filter Size": 7453231, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-05T00:36:35+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 127443, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 12824480, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "11m57.789394043s", "Retain Status": "enabled"}
2024-09-05T01:45:25+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 5011391, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-05T02:03:24+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 0, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 95117, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "17m58.808633116s", "Retain Status": "enabled"}
2024-09-05T11:47:18+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T03:49:29Z", "Filter Size": 3289478, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-05T12:04:55+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 315, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 91687, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "17m37.095582662s", "Retain Status": "enabled"}
2024-09-05T23:34:45+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-09-01T17:59:59Z", "Filter Size": 198738, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-05T23:34:54+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 6309, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 347191, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "8.531663208s", "Retain Status": "enabled"}
2024-09-06T04:48:51+02:00       INFO    retain  Prepared to run a Retain request.       {"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-09-01T01:57:25Z", "Filter Size": 54497, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-06T05:06:55+02:00       INFO    retain  Moved pieces to trash during retain     {"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 140, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 82791, "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Duration": "18m4.411751676s", "Retain Status": "enabled"}
the others look similar but there are too many lines to post them all
only in node 3 there is still a file pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaaaa-1725415045536926000.pb
Summary
root@92e8b3fc1562:/app/config# cd retain/
root@92e8b3fc1562:/app/config/retain# ls
root@92e8b3fc1562:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node02 bash
root@f4cb9a854a59:/app# cd config/retain/
root@f4cb9a854a59:/app/config/retain# ls
root@f4cb9a854a59:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node03 bash
root@d9e99e216bec:/app# cd config/retain/
root@d9e99e216bec:/app/config/retain# ls
pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa-1725415045536926000.pb
root@d9e99e216bec:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node04 bash
root@ff04a1c0baa5:/app# cd config/retain/
root@ff04a1c0baa5:/app/config/retain# ls
root@ff04a1c0baa5:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node05 bash
root@68dcf7aed515:/app# cd config/retain/
root@68dcf7aed515:/app/config/retain# ls
root@68dcf7aed515:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node06 bash
root@56dee99dbfd5:/app# cd config/retain/
root@56dee99dbfd5:/app/config/retain# ls
root@56dee99dbfd5:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node07 bash
root@aff5089454b7:/app# cd config/retain/
root@aff5089454b7:/app/config/retain# ls
root@aff5089454b7:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node08 bash
root@d56b6473f535:/app# cd config/retain/
root@d56b6473f535:/app/config/retain# ls
root@d56b6473f535:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node09 bash
root@db455dd28df0:/app# cd config/retain/
root@db455dd28df0:/app/config/retain# ls
root@db455dd28df0:/app/config/retain# exit
exit
root@storj-chia01:~# docker exec -it storj-node10 bash
root@8158210504de:/app# cd config/retain/
root@8158210504de:/app/config/retain# ls
root@8158210504de:/app/config/retain# exit
exit
Interesting, my biggest node still processing them
$ ls -l /mnt/x/storagenode2/retain/
total 6872
-rw-r--r-- 1 root root   56321 Sep  6 00:48 pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa-1725415045536926000.pb
-rw-r--r-- 1 root root  248794 Sep  5 23:49 qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa-1725472799875480000.pb
-rw-r--r-- 1 root root 6727079 Sep  5 12:18 ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa-1725299999997633000.pb
Node 3 is my biggest node and recently got the update so the used space filewalker is still running, here are the logs from yesterday until now. A Bloom filter is still being processed
2024-09-05T23:51:56+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess gc-filewalker completed {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "piecesCount": 77450, "Total Pieces To Trash": 271, "Trashed Pieces": 271, "Pieces Skipped": 0}
2024-09-05T23:52:29+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess finished successfully        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-06T03:48:34+02:00       INFO    lazyfilewalker.gc-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-06T03:48:34+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess started      {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-06T03:48:34+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess Database started        {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode"}
2024-09-06T03:48:34+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess gc-filewalker started   {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "createdBefore": "2024-09-01T17:59:59Z", "bloomFilterSize": 211576}
2024-09-06T03:51:09+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess gc-filewalker completed {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Process": "storagenode", "piecesCount": 369002, "Total Pieces To Trash": 6003, "Trashed Pieces": 6003, "Pieces Skipped": 0}
2024-09-06T03:51:09+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess finished successfully        {"Process": "storagenode", "satelliteID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-09-06T07:34:48+02:00       INFO    lazyfilewalker.gc-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-06T07:34:48+02:00       INFO    lazyfilewalker.gc-filewalker    subprocess started      {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-09-06T07:34:48+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess Database started        {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode"}
2024-09-06T07:34:48+02:00       INFO    lazyfilewalker.gc-filewalker.subprocess gc-filewalker started   {"Process": "storagenode", "satelliteID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Process": "storagenode", "createdBefore": "2024-09-01T01:57:25Z", "bloomFilterSize": 48364}
2024-09-06T08:02:56+02:00       INFO    lazyfilewalker.used-space-filewalker    subprocess finished successfully        {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-09-06T08:02:56+02:00       INFO    pieces  used-space-filewalker completed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 4242669556248, "Total Pieces Content Size": 4233451711000}
2024-09-06T08:02:56+02:00       INFO    pieces  used-space-filewalker started   {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-06T08:02:56+02:00       INFO    lazyfilewalker.used-space-filewalker    starting subprocess     {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-06T08:02:56+02:00       INFO    lazyfilewalker.used-space-filewalker    subprocess started      {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-09-06T08:02:56+02:00       INFO    lazyfilewalker.used-space-filewalker.subprocess Database started        {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
The retain folder is empty.
Storage used by satellites (No Saltlake on the node):
AP1: 178GB
EU1: 1.437TB
US1: 5.335TB
The trash folder:
β€œNode Location”/storage/trash/
β”‚ └── 2024-09-05
β”‚ └── 2024-09-05
Some stats about the trash folder using:
du -s --si --apparent-size β€œNode Location”/storage/trash/β€œSat folder”
find β€œNode Location”/storage/trash/β€œSat folder”/ -type f | wc -l
Trash: AP1
12G /qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa/
Files:
43336
Trash: EU1
4,1k /v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/
Files:
0
Trash: US1
230G /ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa/
Files:
1714086
The logs are rotated every 14 days, so they go back up to 2024-08-24
EU1:
|node.log.11:2024-08-26T21:19:48Z|INFO|retain|Prepared to run a Retain request.|{Process: storagenode, cachePath: config/retain, Created Before: 2024-08-22T17:59:59Z, Filter Size: 1927855, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs}|
|node.log.11:2024-08-26T21:28:25Z|INFO|retain|Moved pieces to trash during retain|{Process: storagenode, cachePath: config/retain, Deleted pieces: 104353, Failed to delete: 0, Pieces failed to read: 0, Pieces count: 3395653, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Duration: 8m37.647282308s, Retain Status: enabled}|
|node.log.12:2024-08-24T22:49:47Z|INFO|retain|Prepared to run a Retain request.|{Process: storagenode, cachePath: config/retain, Created Before: 2024-08-20T17:59:59Z, Filter Size: 1925576, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs}|
|node.log.12:2024-08-24T22:58:00Z|INFO|retain|Moved pieces to trash during retain|{Process: storagenode, cachePath: config/retain, Deleted pieces: 67879, Failed to delete: 0, Pieces failed to read: 0, Pieces count: 3403176, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Duration: 8m12.590182705s, Retain Status: enabled}|
The other satellites:
AP1:
node.log.1:2024-09-05T21:47:00Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-09-01T17:59:59Z", "Filter Size": 364488, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
node.log.1:2024-09-05T21:52:00Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 15571, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 644178, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "4m59.745727594s", "Retain Status": "enabled"}
node.log.10:2024-08-27T19:14:40Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-23T17:59:59Z", "Filter Size": 349403, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
node.log.10:2024-08-27T19:23:24Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 12227, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 607608, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "8m44.000575773s", "Retain Status": "enabled"}
node.log.12:2024-08-25T21:48:48Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-21T17:59:59Z", "Filter Size": 348674, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
node.log.12:2024-08-25T21:51:22Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 14868, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 614132, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "2m33.573072564s", "Retain Status": "enabled"}
node.log.14:2024-08-23T00:44:55Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-18T17:59:59Z", "Filter Size": 349116, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
node.log.14:2024-08-23T00:48:46Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 25006, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 626709, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "3m51.637681317s", "Retain Status": "enabled"}
node.log.2:2024-09-04T02:24:08Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-30T17:59:59Z", "Filter Size": 360564, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
node.log.2:2024-09-04T02:25:59Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 7061, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 638909, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "1m50.498149264s", "Retain Status": "enabled"}
node.log.4:2024-09-01T22:01:37Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-28T17:59:59Z", "Filter Size": 353233, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
node.log.4:2024-09-01T22:03:39Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 14111, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 638284, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "2m1.737823778s", "Retain Status": "enabled"}
node.log.8:2024-08-29T20:04:55Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-25T17:59:59Z", "Filter Size": 350395, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
node.log.8:2024-08-29T20:07:09Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 6593, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 606622, "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Duration": "2m13.560425143s", "Retain Status": "enabled"}
US1:
node.log.1:2024-09-05T06:29:45Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-30T17:59:59Z", "Filter Size": 18146793, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
node.log.1:2024-09-05T08:37:16Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 379912, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 31782952, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "2h7m30.793173042s", "Retain Status": "enabled"}
node.log.11:2024-08-26T15:11:27Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-20T17:59:59Z", "Filter Size": 17945127, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
node.log.11:2024-08-26T16:18:46Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 388200, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 31643562, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "1h7m18.806154758s", "Retain Status": "enabled"}
node.log.13:2024-08-24T15:19:12Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-18T17:59:59Z", "Filter Size": 17877570, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
node.log.13:2024-08-24T18:42:16Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 475552, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 31683826, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "3h23m4.21985355s", "Retain Status": "enabled"}
node.log.3:2024-09-03T01:22:11Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-28T17:59:59Z", "Filter Size": 18182225, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
node.log.3:2024-09-03T02:53:50Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 549540, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 31793965, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "1h31m39.00878272s", "Retain Status": "enabled"}
node.log.5:2024-09-01T13:43:51Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-26T17:59:59Z", "Filter Size": 18121249, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
node.log.5:2024-09-01T14:45:15Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 387658, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 31900949, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "1h1m24.296874475s", "Retain Status": "enabled"}
node.log.7:2024-08-30T01:35:24Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-24T17:59:59Z", "Filter Size": 18029727, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
node.log.7:2024-08-30T02:39:09Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 396976, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 31710376, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "1h3m45.614155439s", "Retain Status": "enabled"}
node.log.9:2024-08-28T13:47:23Z	INFO	retain	Prepared to run a Retain request.	{"Process": "storagenode", "cachePath": "config/retain", "Created Before": "2024-08-22T17:59:59Z", "Filter Size": 17951613, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
node.log.9:2024-08-28T14:53:16Z	INFO	retain	Moved pieces to trash during retain	{"Process": "storagenode", "cachePath": "config/retain", "Deleted pieces": 425246, "Failed to delete": 0, "Pieces failed to read": 0, "Pieces count": 31714791, "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Duration": "1h5m52.203743891s", "Retain Status": "enabled"}
I got EU1 bloom filter today.
During the night all nodes received their bloom filters from EU1, moved around 1.5TB data into trash.
Sadly more than the ingress on EU1 this month so far, s**t happens. :frowning:
This is interesting, my nodes are close to Europe, but holds more than 80% for US1, and very little for Saltlake, AP1 and EU1.
Similar to me, the distribution for my nodes:
Storage total: 79,412TB
AP1: 2,49%, 1,977TB
EU1: 17,97%, 14,274TB
US1: 79,54%, 63,165TB
I can confirm (also based in Europe):
For me it looks strange, however, I have one of explanations. Take a look on a map how the nodes are distributed. It’s highly concentrated almost in the central Europe, and, I guess, many customers wants to comply with GDPR.
I also got a filter for all nodes during the night
My nodes are in Germany and I also have more US data. I think this is simply because there are more US customers than EU customers and data.
grafik
Also received EU1 BF for my nodes today.
                                        Deleted        Failed to          Piece
      Timestamp            Node          pieces       delete/read         count          Duration       Satellite
2024-08-22T16:23:06+02   server002        195.750         0 / 0        23.011.336        33m23.79s        US1
2024-08-24T20:03:48+02   server002        582.883         0 / 0        22.972.975        24m35.72s        US1
2024-08-26T07:03:30+02   server002        213.279         0 / 0        22.464.389        22m29.48s        US1
2024-08-28T18:54:35+02   server002        226.308         0 / 0        22.498.922         24m5.13s        US1
2024-08-30T11:11:23+02   server002         97.907         0 / 0        22.400.163        18m40.21s        US1
2024-09-01T09:03:00+02   server002        212.540         0 / 0        22.458.094         23m8.52s        US1
2024-09-03T09:39:31+02   server002        161.988         0 / 0        22.270.149        20m57.30s        US1
2024-09-05T01:54:42+02   server002        213.078         0 / 0        22.187.598        19m13.68s        US1
2024-09-07T04:52:47+02   server002        211.965         0 / 0        21.947.792        19m39.59s        US1
2024-08-22T07:09:28+02   server002         18.077         0 / 0         2.643.830         5m35.60s        EU1
2024-08-24T23:33:12+02   server002         66.472         0 / 0         2.647.534         8m14.30s        EU1
2024-08-27T00:38:04+02   server002         53.229         0 / 0         2.603.227        17m30.34s        EU1
--> 2024-09-08T01:45:11+02   server002    173.759         0 / 0         2.664.025        10m59.21s        EU1
2024-08-22T21:00:09+02   server002         13.943         0 / 0           686.693          2m4.58s        AP1
2024-08-26T01:22:30+02   server002          6.081         0 / 0           677.412         1m13.56s        AP1
2024-08-28T01:18:15+02   server002          4.256         0 / 0           675.327          1m0.39s        AP1
2024-08-30T02:24:45+02   server002          2.988         0 / 0           674.380          1m1.95s        AP1
2024-09-02T02:05:35+02   server002          8.701         0 / 0           681.794         1m31.60s        AP1
2024-09-04T01:26:38+02   server002          3.154         0 / 0           673.840          1m5.77s        AP1
2024-09-06T00:07:29+02   server002          5.985         0 / 0           674.252           52.03s        AP1
2024-08-22T09:23:44+02   server002         15.210         0 / 0         4.831.602        16m43.66s     Saltlake
2024-08-24T10:44:27+02   server002          8.473         0 / 0         4.707.968        11m20.96s     Saltlake
2024-08-25T07:14:59+02   server002      3.870.170         0 / 0         4.686.604        40m25.29s     Saltlake
2024-08-25T21:42:23+02   server002            120         0 / 0           803.455           45.02s     Saltlake
2024-08-26T11:38:09+02   server002              0         0 / 0           788.182           39.89s     Saltlake
2024-08-27T09:13:09+02   server002            117         0 / 0           768.763           39.32s     Saltlake
2024-08-28T01:05:30+02   server002              0         0 / 0           755.259           38.34s     Saltlake
2024-08-28T08:36:40+02   server002            202         0 / 0           749.362            5.51s     Saltlake
2024-08-28T22:03:42+02   server002              8         0 / 0           742.446           40.87s     Saltlake
2024-08-29T18:41:09+02   server002              2         0 / 0           729.993           37.06s     Saltlake
2024-08-30T05:25:39+02   server002              7         0 / 0           708.892           37.92s     Saltlake
2024-08-30T11:43:12+02   server002          1.916         0 / 0           698.862           54.97s     Saltlake
2024-08-30T19:40:01+02   server002              0         0 / 0           682.612            2.79s     Saltlake
2024-08-31T12:38:22+02   server002            289         0 / 0           627.562           38.69s     Saltlake
2024-08-31T16:07:00+02   server002              1         0 / 0           616.695            2.12s     Saltlake
2024-09-01T00:40:29+02   server002              0         0 / 0           586.248           14.04s     Saltlake
2024-09-01T11:22:25+02   server002             78         0 / 0           558.569           36.11s     Saltlake
2024-09-02T02:08:56+02   server002            125         0 / 0           533.010           34.87s     Saltlake
2024-09-02T05:00:47+02   server002            371         0 / 0           524.050            5.06s     Saltlake
2024-09-02T21:12:58+02   server002            378         0 / 0           477.358            5.25s     Saltlake
2024-09-03T03:29:42+02   server002             23         0 / 0           457.064           20.40s     Saltlake
2024-09-03T10:50:27+02   server002            727         0 / 0           431.988           36.98s     Saltlake
2024-09-03T14:45:19+02   server002             10         0 / 0           416.895            1.58s     Saltlake
2024-09-04T00:45:50+02   server002             27         0 / 0           387.683            1.49s     Saltlake
2024-09-04T12:42:33+02   server002              0         0 / 0           386.880            1.46s     Saltlake
2024-09-05T00:16:50+02   server002              0         0 / 0           375.358            1.42s     Saltlake
2024-09-05T14:45:04+02   server002          2.166         0 / 0           353.795           36.67s     Saltlake
2024-09-06T01:17:07+02   server002          2.162         0 / 0           326.319           10.04s     Saltlake
2024-09-06T11:37:24+02   server002            740         0 / 0           300.407            1.75s     Saltlake
2024-09-06T20:10:04+02   server002            104         0 / 0           281.605            1.22s     Saltlake
2024-09-07T02:35:33+02   server002            743         0 / 0           270.136            2.63s     Saltlake
2024-09-07T13:20:59+02   server002             46         0 / 0           249.112           27.76s     Saltlake
2024-09-07T23:19:30+02   server002            450         0 / 0           239.341            2.04s     Saltlake
2024-09-08T08:37:44+02   server002            507         0 / 0           231.311           20.65s     Saltlake
Th3Van.dk
