No connection to my Dashboard
Hi, i´m new to storj.
Install today my node. My router is Fritzbox 7360. Port forwarding done, firewall allowed but no connection to local.host. After that disable windows firewall, set Exposed Host in my router, nothing, no connection, pls help.
Hello @kurok25,
Please, go through the check-list first:
You really should not expose your Windows PC to the whole Internet.
I have the same issue, did you ever resolve this ? I noticed post was from a few months back ?
The solution at the moment to use the Chrome or Firefox, probably without some extensions, which could block the JS.
