As written in the title there is no data I/O on my node. It is normal because of weekend or it is a problem on my node? Dashboard says that i’m online and there are no errors in logs.
I think traffic was super low… I’ve seen only “GET_AUDIT” in the logs for the last 150+ entries… IMO that is normal due to update phase, the 3 days directly after update most of the time network activity is quite low.
Since Storj isn’t mining you can’t expect regular traffic. As long as you don’t see errors in your log and your node is online you are good.
I see up and downloads again… So there should be a bit more coming your way as well.
