I had zero ingest for two days or so.
I docker stop the node and then docker start and the ingest is immediately fixed.
I have other nodes on the same pc that were fine and egress was not affected.
There were no errors in the logs.
So what can I look at?
I had the same issue on some of my nodes a few days ago. After a restart everything was fine again. There were no errors in the logs.
Also I noticed the same thing on my two nodes, input close to zero… Meanwhile I had a lot of I/O
Alexey
January 22, 2023, 6:14am
4
Did you have a downtime in between?
You may check with these scripts:
Would you mind to provide dashboard from the uptimerobot?
And also, please, provide result of the command:
PowerShell
foreach ($item in ((Invoke-WebRequest http://localhost:14002/api/sno).Content | ConvertFrom-Json).satellites.id) {
((Invoke-WebRequest http://localhost:14002/api/sno/satellite/$item).Content | ConvertFrom-Json).auditHistory.windows |
Where-Object{$_.totalCount -ne $_.onlineCount} | ForEach-Object{Write-Host $item; $_ | Format-Table -AutoSize}
bash
for item in `…
Yes, I restarted the node before the ingress stopped.
I have installed a new internet router today so hopefully that will fix things
