I seem to have no ingress, what should I do?
docker exec -it storagenode /app/dashboard.sh … shows >
Last Contact ONLINE
Uptime 541h55m19s
Available Used Egress Ingress
Bandwidth N/A 40.3 GB 40.3 GB 2.7 MB (since Sep 1)
Disk 8.6 TB 449.7 GB
Other info … (the trash is empty).
gs.gs
September 10, 2020, 8:40am
3
Please update your software. I’m on version 1.11.1
thej
September 10, 2020, 8:41am
4
Try to update your node.
Seems like minimal version is 1.9.0
Damn it, I’ve not been here for long! LOL
Is there a simple command to update it? … and also a proper way to shut down/restart?
thej
September 10, 2020, 8:44am
6
It is best to use the Watchtower, it updates your node automatically.
tried manual start but got the message …
Blockquote Error response from daemon: Conflict. The container name “/storagenode” is already in use by container “bxxxxxxxxxxxxxxxxxxxxxxxxxxxxxa”. You have to remove (or rename) that container to be able to reuse that name.
First remove the existing container.
Stop the running Storage Node container
2. Remove the existing container
Pull the latest image from docker
Start your storage node again by running the following command after editing
I initially went for automatic Watchtower but needed manual install of docker image.
